Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Sep 2021
    Canada
    Menzerna 3 step process
    I'm looking to bring my '81 z28 original paint back to life, it came from the factory with water base paint. I Know the outcome will not be a show car but I would like to get rid of the deep scratches and swirls.
    Have any of you guy's used Menzerna before?, I'm a little confused with all the different numbers and line of products.
    I'm looking for a 3 stage process along with the matching buffing pads.
    Before polishing I intend to use Mothers Clay bar kit
  2. Likes Klasse Act liked this post
  3. #2
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Menzerna 3 step process
    Do a test spot. Menz 400 and a yellow Rupes pad might be all you need.
  4. #3
    Feb 2015
    470
    Why so aggressive instead of just make it shine and preserve the paint if it is original?
  5. #4
    May 2013
    TN
    1,768
    Quote Originally Posted by wing commander View Post
    OP mentioned deep scratches and though the compound is aggressive, the pad isn’t.
  6. Thanks wing commander thanked for this post
    Likes dwaleke liked this post
  7. #5
    Aug 2013
    St Louis metro (Illinois)
    5,811
    Great looking car. I think that generation is the best looking Camaros Chevy ever built.
    I have two thoughts.
    1. Just because you have a big job to do, don't automatically assume you'll need to do a three stop process. Let the paint be your guide. It might take three steps, or it might only need two depending on product/pad usage
    2. Menzerna makes great products from what I understand, but they do have a pretty diverse product line. I'm not sure I'd be able to easily pick out the right products I need for my uses without some research...beyond 400 which is clearly their compound. You might look at the Griots Boss Products or other who simply offer a compound, medium polish/swirl remover, and a finishing polish.
    All that said, if you're starting from scratch I would have three levels of polish on hand (compound, medium cut, fine cut), and at least a handful of compounding/cutting pads and polishing pads. With two pad choices and three polishes at your disposal you can mix and match to see what works best. You may be able to polish out most of the car with the polishes and save the compound for the worst areas on the car. You can specifically target some areas which need more effort and treat other areas more gentle because they don't need as much work. This will save you time, products, and only reduce the paint on your car where it is absolutely needed.
  8. Likes Jim w liked this post
  9. #6
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Can you take a light and capture the damage you're trying to correct like the picture shown below.....
    Ripping through your mind like a hurricane full of novocaine
  10. #7
    Sep 2021
    Canada
    Thanks for the reply,
    The car has some deep scratches in lots of areas, also I was detailing the engine bay and I did a horrible job at masking off the car and got lots of fine mist of paint all over the car, the car is currently very dusty and I will begin with a wash and clay bar.
    here are some pictures
    Menzerna 3 step process-image_67164417-jpg
    Menzerna 3 step process-image_50368257-jpg
    Menzerna 3 step process-image_167832065-jpg
  11. #8
    Aug 2020
    Minnesota
    593
    First pass I would try Menzerna 400 with a Lake Country microfiber pad then finish with a Buff & Shine orange pad with CarPro Essence
  12. #9
    Sep 2021
    Canada
    so you would start with this :
    Medium Cut Polish 2400
    Medium Cut Polish 2400 | menzerna polishing compounds GmbH & Co. KG
    and end with this ?
    Medium Cut Polish 2500 | menzerna polishing compounds GmbH & Co. KG
    I'm so confused and there different stages
    I appreciate all the help
  13. #10
    Aug 2020
    Minnesota
    593
  1. Menzerna 3 step process needed?
    By YankeeFan in forum Auto Detailing 101
    Last Post: 06-25-2017, 06:58 AM
  2. How much to charge for a 2 step process for a F-150
    By patricemougeot in forum Auto Detailing 101
    Last Post: 05-19-2017, 08:01 AM
  3. One step process
    By duffthebluff in forum How to make money detailing cars
    Last Post: 07-20-2015, 09:26 PM
  4. Your one step process.
    By BigCat in forum Auto Detailing 101
    Last Post: 04-20-2015, 12:19 PM
  5. AIO or two-step process?
    By Pjstockford in forum Hot topics & Frequently Asked Questions
    Last Post: 10-31-2014, 11:22 PM
