Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jun 2021
    Carpro Eraser vs Other Brand IPA
    Planning ahead for my next major detail and stocked up on supplies this week. I'm going to try my first attempt at a ceramic coating on my F150 and bought some CarPro products. I bought Iron X, Cquartz UK and Reload.
    My truck currently has a layer of Wolfgang SiO2 Sealant and Collinite 845 wax which will be 6 months old by the time I apply the Cquartz. I currently own a bottle of Mothers CMX Surface Prep with a lot of product left; will this work in the place of a bottle of Carpro Eraser? I didn't buy Eraser but everything I'm reading says to use it first...just wondering if most IPA products are created equal?
    Lastly, will the combination of a hand wash, claybar, Iron X and Surface Prep be enough to remove the remaining wax & sealant and get the paint ready for the Cquartz? Or do I need to also polish the paint with a DA before the coating? I do not have any swirls or need to do any paint correction...but willing to take the extra step if necessary.
    Thanks for the info,
    Super Member TroyScherer's Avatar
    Sep 2009
    Ohio
    1,912
    Re: Carpro Eraser vs Other Brand IPA
    While I think many will tell you that most all of these Surface Prep products are the same and to use whatever you have and want; I have found that there is a difference in some being stronger, slicker, having other added prep bonding products built in, etc.
    Personally I have found the best results from using the correct prep product for the coating base don the mgft recommendations. This is also one of the first questions asked if you have a bad experience or durability from a coating.
    If you want to be absolutely sure you don't have any sealant or wax left on the vehicle a prep polish is your best bet. In my use clay bars don't necessarily remove anything other than contaminates and Iron-X and a car was are the same. If a sealant or wax is still holding strong and prep spray won't necessarily remove them either.
  3. Thanks trailrunz thanked for this post
  4. #3
    Aug 2020
    926
    I'd say that any wax remover would remove 845 and Wolfgang. Any ISO will clean the paint. As to whether their are specific bonding agents in Eraser, you'd have to ask the manufacturer.
  5. #4
    Super Member vaca22's Avatar
    Feb 2020
    381
    I use(d) Mother's CMX Surface because it's what's around. Seemed ok, but as Troy mentioned above I think some are stronger than others; Mother's CMX I believe is rather gentle.
    Gtechniq's PW is supposed to be really strong.
  6. #5
    Jun 2021
    Quote Originally Posted by vaca22 View Post
    Thanks for the info so far.
    As far as a polish, is CarPro Essence a good option just to keep synergy going?
  7. #6
    SELF BANNED
    Jun 2019
    1,076
    Quote Originally Posted by trailrunz View Post
    Many people will give you different answers that's per the course. I'm not a professional so take my views with a grain if salt.
    I don't have direct experience but i was told in a private email by someone in the car care products business that these primer polishes are not that great at "adding" durability. I even seen a post by a professional detailer that he as experienced a decrease in durability.
    Besides that essence doesn't have much cut, i would use a true 1 step myself like 3D One. It will cut a lot more and still leave a wax ready finish with a medium pad on most any paint.
    And even another thing to keep in mine i seen another professional say primer polishes give average joes the chance to really up their game on the finish. They do finish great.
    But personally if i was going to go over a car with a polisher once it would be a medium cut polish.
  8. #7
    Super Member Rsurfer's Avatar
    Jan 2007
    14,110
    Quote Originally Posted by noorth View Post
    What about the oils left behind by some polishes?
  9. #8
    Aug 2013
    St Louis metro (Illinois)
    5,847
    The advantage, as I understand them to products like Essence and Gyeon Primer is the fact you don't need to do a surface prep afterwards. When using a "normal" polish, you'll need to use a surface prep afterwards to remove all the polishing oils and ensure the surface is as clean as possible before applying a coating.
    As for Eraser vs the others? I've used Gyeon Prep and Eraser. Both worked well and I used them with several different brands of coatings just fine. The Gyeon has more lubrication, but I think Eraser cleaned better (IMO). Both are good and to say one is better than the other is splitting hairs.
  10. #9
    SELF BANNED
    Jun 2019
    1,076
    Not sure of your question. I assume your referring to a panel wipe? I always use one but it seems products are popping up that claim you can go right over the polish without waiting.
    Many professionals do a light IPA "dust" wipe the next day when they use gyeon. I know i would.
  11. #10
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Given that this is the first time you are using a coating, I would invest in Eraser along with at a minimum a polish to remove the protection you currently have to have a clean surface the coating can bond to regardless if you don't have any swirls. Or we will be seeing a post 6 months later how underwhelmed you are with the performance of the coating.
    You can quickly zip over the surface with a polishing pad and be done. No need to focus on correction since your paint is defect free to your liking.
    Yvan has some good information and this is worth watching.
    Take it with a grain of salt. Too many factors in prep and unless this person has real proof or actual data then his claim has no merit. How many other users have had no issues with a primer polish. This goes for professional detailers. How would they know unless they see the car daily and can see what is going on. Who knows what the client does with their personal vehicle.
    I don't listen to any of these people but rather use my own personal experience. And based on my experience a primer polish has no negative impact on a coating.
    Still recommended for Essence. Gyeon needs 24 hours before coating but recommended to panel wipe if not able to wait that 24 hours. Dr. Beaseley's doesn't require a panel wipe for their primer polishes which I have also used.
  12. Thanks trailrunz, Desertnate thanked for this post
    Likes noorth liked this post
  1. CarPro Eraser
    By KyleWrap in forum Products Guides
    Last Post: 03-30-2015, 02:14 AM
  2. Where to buy carpro eraser
    By sweeris in forum Off-Topic
    Last Post: 03-09-2014, 11:54 AM
  3. Carpro's Eraser
    By Rsurfer in forum Products Guides
    Last Post: 01-03-2012, 01:01 PM
  4. I'm not so sure about CarPro Eraser...
    Last Post: 12-23-2011, 07:26 AM
  5. Carpro Eraser too much IPA?
    Last Post: 12-07-2011, 05:56 PM
