Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Aug 2021
    Help needed removing Aquapel
    New car and novice detailer here. Thought I was making my life a bit easier by applying Aquapel to the windshield to ease in cleaning and shed some water. Had our first rain shower this past week since applying and things couldn't have turned out worse. Not only does the water not bead up all that well, but now the wipers chatter to the point where they're a safety hazard, leaving more than half the windscreen covered in water, which is not even to mention how maddening the sound is.
    I first tried to remove it with some Invisible Glass, which needless to say, made the chattering worse if nothing else. Followed that up by some 100% IPA, then tried 100% MeOH, and then Griots Glass Clay Bar and Fine Glass Polish (by hand), none of which made any difference. I was hesitant to try anything else, like Bon Ami or using glass polish with a DA, but I'm really in need of some help here.
    Any suggestions would be massively appreciated.
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Re: Help needed removing Aquapel
    Try using the glass polish with a DA Polisher. If that doesn't remove it step up to a compound with a DA Polisher.
    I always recommend polishing the glass surface first before applying the Aquapel Glass Treatment & Rain Repellent to help remove any contaminants on the surface and let the Aquapel bond properly to the glass surface.
    How hold are your windshield wiper blades? Wiper chatter is usually caused by contaminated glass surface, bent wiper arm, or the rubber blades are no longer flexing properly and need to be replaced.
  3. Thanks Camhabib thanked for this post
  4. #3
    Jun 2016
    82
    Bon-Ami will not hurt glass, I would try that it has always got my glass very smooth.
  5. Thanks Camhabib thanked for this post
  6. #4
    Mar 2011
    PA
    5,794
    Stoner Glass Stripper
    Get it here or got mine at the local Advanced Auto.
    2018 Colorado ZR2
  7. Thanks Camhabib thanked for this post
  8. #5
    Aug 2021
    Quote Originally Posted by Bobby B. View Post
    Thanks for the reply! I don’t have a DA on hand at the moment (usually borrow a friends) but I can certainly swing by and pick it up if you think that’ll have better results than by hand. Any idea on the correct pad to use?
    As far as the blades, the car has ~1000 miles on it and the wipers worked perfectly before the Aquapel went on. I’ve cleaned both the blades and windshield several times, which makes me believe it’s something related to the Aquapel specifically, rather than contaminants / fault wipers / etc.
  9. #6
    Aug 2021
    Quote Originally Posted by pro 4x View Post
    I saw this online but wasn't sure how much, if at all, better it was than the Griots stuff I have on hand. Any idea the difference?
  10. #7
    Mar 2011
    PA
    5,794
    Never used the Griots. The STONER did indeed strip the glass clean.
    2018 Colorado ZR2
  11. #8
    Aug 2021
    Appreciate it. Ordered some, I'll give it a shot when it comes in.
  12. Likes PA DETAILER liked this post
  13. #9
    Aug 2021
    Update on this saga. Tried the Stoners Glass Stripper and it worked perfectly. You could actually see the Aquapel coming off the glass as I scrubbed. Took a bit of elbow grease but was absolutely worth it.
  14. Likes Bruno Soares, dgage liked this post
  15. #10
    Sep 2009
    2,355
    I'm glad the Stoner Glass Stripper removed the Aquapel Glass Treatment & Rain Repellant for you.
    Aquapel Glass Treatment, Rain Repellent, glass sealant, windshield protectant, Aqua-pel glass wipe
  1. Something better than aquapel?
    By JHForman in forum Auto Detailing 101
    Last Post: 09-23-2019, 05:59 PM
  2. Removing Red Oxide Primer from car paint - advice needed
    By lawrenceSA in forum Auto Detailing 101
    Last Post: 02-19-2014, 06:58 AM
  3. HELP needed removing product from clear bra!!!
    By mg6045 in forum Auto Detailing 101
    Last Post: 04-06-2013, 07:04 AM
  4. Wax Removing Towels Needed
    By Nick B in forum Auto Detailing 101
    Last Post: 08-28-2011, 10:00 PM
  5. aquapel q's
    By orionz06 in forum Auto Detailing 101
    Last Post: 02-15-2009, 09:36 PM
