Page 1 of 2 12 LastLast
Results 1 to 10 of 18
    Jun 2020
    49
    Why wheel cleaner causes brake disc rust?
    Why wheel cleaner causes brake disc rust? We're talking about bloody wheel cleaner. How to find wheel cleaners that don't cause rust ?
    Sep 2016
    91
    Re: Why wheel cleaner causes brake disc rust?
    It's probably from the water after rinsing the cleaner off causing rust. There is a product that will stop this but I can't recall the name right now. But I don't think the issue is the wheel cleaner itself.
    Sent from my SM-N986U using Tapatalk
    Dec 2011
    Pompano Beach, Fl
    1,494
    Never had a wheel cleaner cause rust. Any rust or on the disc rotor itself is usually gone after I drive it. if you really want to make sure you don’t get any rust user leaf blower to dry the whole assembly after you clean it
    Glen -
    Feb 2012
    Palatine Illinois, USA
    24,594
    Get some Brake Buster Why wheel cleaner causes brake disc rust?Why wheel cleaner causes brake disc rust?Why wheel cleaner causes brake disc rust?
    2022 Elantra N Cyber Gray
  5. Likes DFB liked this post
  6. #5
    Aug 2013
    St Louis metro (Illinois)
    5,821
    What part of the brake rotor are you talking about. The hats, the outside edges of the rotors, or the faces of the rotors where the pads make contact. Any form of moisture will cause certain areas to rust.
    Depending on the brand of the rotor, most will rust along the edges and the hats simply because they are untreated steel and you have to live with it. The rotor faces will rust quite quickly when they get wet, but it will go away the first time you drive the car and use the brakes to stop or gradually slow down.
    Most of the time rust on the hats and edges of the rotors is unsightly, but harmless. Fortunately I've seen a few aftermarket brands these days offer rotors with edges/hats which are painted/treated with some material to prevent them from rusting. That's the route I'm going whenever my current set of rotors wear out.
  7. #6
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    400
    Quote Originally Posted by supercharged75 View Post
    Hydes Serum
    Hyde's Serum Rust Stopper, rustopper, anti-rust solution for wheels
  8. #7
    Nov 2015
    Los Angeles, California
    13,778
    Does it actually prevent it from happening?
    Someone should demonstrate/compare it vs. a typical wheel cleaner. You’d figure the manufacture would’ve shown it instead of just claim it. I know if my product could do that you’d never see the end of it.Why wheel cleaner causes brake disc rust?lol.
    ….Just imagine… “El Cheapo Wheel Cleaner” with brake preserver. Never have ugly brakes again!
  9. #8
    Feb 2012
    24,594
    It reduces it consuderablyWhy wheel cleaner causes brake disc rust?
  10. #9
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Moisture will cause surface rust on your brake rotors. Hyde's Serum Rust Stopper works great, but it's been on a manufacturer backorder for months.
  11. #10
    Aug 2013
    5,821
    I'll just drive my car!
    In all seriousness, typically just pulling my car into the garage after a good wash and lightly riding the brakes will clean the rotor faces of any surface rust. I had no idea a product like this existed. If you do apply this product in the driveway and then pull the vehicle into the garage, I wonder how much of the product will remain on the rotors?
  12. Likes oneheadlite liked this post
  1. Can these rust spots on disc be cleaned ?
    Last Post: 08-03-2020, 07:01 PM
  2. Wheel cleaner as rust remover ??
    By AZpolisher15 in forum Auto Detailing 101
    Last Post: 06-07-2020, 10:10 AM
  3. Replies: 0
    Last Post: 08-03-2019, 12:09 PM
  4. Safe wheel cleaner for red factory painted brake callipers
    By cheekyage in forum Auto Detailing 101
    Last Post: 07-26-2017, 10:09 AM
  5. Brake Rotor Rust
    By jayshut11 in forum Ask your detailing questions!
    Last Post: 11-02-2013, 03:41 PM
