Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Jun 2020
    49
    Brake cleaner for removing wax?
    Hello
    Can I use brake cleaner for removing wax? Also what do you think about using Extraction naphtha for wax removing?
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Re: Brake cleaner for removing wax?
    No need to remove wax with brake cleaner.
    If it's a carnauba wax leave your vehicle in the sun for a day lol.
    What do you got going on that you're wanting done?
    One pass with a fine polish and a da will remove it easily. 20 min. of work.
    Ripping through your mind like a hurricane full of novocaine
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by locarno View Post
    for removing wax?
    Not if it is a “Chlorinated” brake cleaner!!
    •Better yet:
    -Don’t chance using chlorinated brake
    cleaner to clean anything: a heat induced
    by-product—methane gas—is a real killer.
    -If you have any at your residence:
    please dispose of it, responsibly, ASAP.
    {Just a a well-intentioned advisement.}
    With me considering polishing process(es)
    as more efficient means for the total
    removal of Waxes…I have mixed thoughts
    about using Extraction Naptha for the
    specific purpose of Wax removal.
    Of course: YMMV.
    If I may ask:
    What Wax are you using?
    If it takes the above Solvents to
    remove it…I Want Some of It!
    Jun 2020
    49
    Soft99 Fusso coat for dark paints
    Jun 2020
    49
    carnauba wax really removes itself under direct sun? Why?
    Mar 2015
    723
    It has a melting point below what paint reaches under summer sun. Part of the reason it’s more prevalent in Britain than here in Texas.
    Hello
    When I read through your posting history I find it confusing all the "various" questions you ask.
    I figure you're truly here to learn and need help or you're trolling this forum.
    Hello
    I think it's a tick overkill but hey, it's your car.
    Is this for the car you repainted here where you're having problems removing scratches with your 125mm polisher?
    What I'm doing wrong here?
    Or a different car?
    What is the end-goal for this car with wax on it?
    A safer way to remove the wax would be to simply machine polish the car using your 125mm polisher.
    Jun 2020
    49
    Yes. It is all for the same car. I asked about wax removing because I polished the hood and put wax on it. As you know from another thread the polishing was not so good becasue left very scratches. So I need to correct it. I don't want to polish this element because I heard that old wax can clogg up my polishing pad.
  10. #10
    Wax clogging your pad will be no worse than clearcoat clogging your pad. Pads get dirty. Then you clean them.
    Using a brake cleaner, in my opinion is way to harsh and aggressive to remove a microscopic thin layer of wax. Keep it simple, just machine polish to get the wax off or do what you think is best.
  11. Thanks locarno thanked for this post
    Likes locarno, dwaleke liked this post
  1. Replies: 14
    Last Post: 02-19-2018, 05:26 PM
  2. Need help removing brake dust
    By AutoApollo in forum Auto Detailing 101
    Last Post: 09-17-2016, 11:08 PM
  3. Removing meguiars brake dust barrier
    By oboroballa03 in forum Tricks, Tips and Techniques
    Last Post: 08-29-2015, 09:10 AM
  4. Removing brake dust from Audi Calipers
    By jgraham37128 in forum Ask your detailing questions!
    Last Post: 12-15-2013, 08:37 AM
  5. Brake dust removing paint from wheels
    By nissenc1337 in forum Auto Detailing 101
    Last Post: 08-02-2013, 01:33 PM
