Results 1 to 4 of 4
    Sep 2016
    40
    Headlight Restoration Help/Advice
    Hi all,
    My 2017 Subaru Legacy's headlamps UV coat is starting to peel on the top of them. What is the best way to tackle this? I really don't want to have to spend a fortune replacing the headlamps, so if there is an easy way to remedy this that would be great!
    I guess my question is, will the Meguiar's kit do the trick? I am nervous about sanding the headlight. Has anyone else done this with success?
    Any thoughts/suggestions would be appreciated.
    Thanks!
    Attached Thumbnails Attached Thumbnails Headlight Restoration Help/Advice-sub1-jpg
    Jun 2021
    Re: Headlight Restoration Help/Advice
    I used the meg headlight kit in a blue box. Was very easy to follow and use. That was almost 2 years ago and the headlights still look great.
    Sep 2016
    40
    Quote Originally Posted by Bigben5239 View Post
    Perfect, I'll give it a whirl! That is the same exact kit I just ordered.
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,450
    Chances are that will simply polish off. Meg's has a great headlight kit with a 3" Drill attachment, etc included. If you simply polish you may not require a spray on 2k clear or coating be applied. Just seal them up. Sanding overall isn't difficult. Just wet sand that with some 2000-3000 grit and polish back. Higher grits like that may take a bit longer but it's light damage and super easy to finish out. If you do sand, make sure you use Meg's spray on Headlight Coating after.
    2023
  1. Any advice on starting headlight restoration business ?
    By rcro57 in forum How to make money detailing cars
    Last Post: 12-11-2018, 04:19 PM
  2. Headlight Restoration Side Job Advice?
    By royalkangaroo in forum How to make money detailing cars
    Last Post: 06-29-2017, 05:49 PM
  3. Replies: 25
    Last Post: 08-12-2016, 01:29 PM
  4. Headlight restoration advice - 2008 BMW X5
    By rudetrini in forum Ask your detailing questions!
    Last Post: 05-06-2016, 02:19 PM
  5. Headlight Restoration New Dealer Wants a Demo Need some Advice
    By Louie_Blu in forum Ask your detailing questions!
    Last Post: 10-21-2011, 01:05 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
