Results 1 to 9 of 9
    Super Member lokerola's Avatar
    May 2011
    Alexandria, VA
    512
    Help - plastic screen stained by 303
    Well folks, this is a new one for me. I've always used 303 interior protectant with no issues. But today I over sprayed some 303 on my dash and it splattered up onto a small plastic screen that sits up high, on the center of my dash. I thought I wiped it off, but after the detail I went for a drive and noticed it still had the 303 splatter marks on it.
    I've tried to remove it with some dish soap and water, then a touch of Windex, and finally some Klasse AIO on a cotton cloth. The Klasse helped a little bit, but nothing else has helped and it's still stained. Any tips, tricks, or ideas to clean this off?
    Thanks!
    Help - plastic screen stained by 303-screen-jpg
    Our Lady Of Blessed Acceleration - Don't Fail Me Now.
    Alex, from Northern Virginia.
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Re: Help - plastic screen stained by 303
    {Hopefully 303 hasn’t chemically
    bonded to/with this plastic part.}
    Quote Originally Posted by lokerola View Post
    Here’s an
    •Try giving the following products a whirl:
    -Meguiars Plastic Care Kit (M10 & M17)
    -Meguiars Plastx Clear Plastic Cleaner
    & Polish
    (G123)
    -Soft Foam Applicator Pads
  3. Likes lokerola liked this post
  4. #3
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    This sucks man. But the lesson to learn is to spray the towel, outside the car, I prefer more than a foot or so away from the car all together.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  5. Likes hoyt66, lokerola liked this post
  6. #4
    May 2011
    Alexandria, VA
    512
    I'll give it a try, thanks!
  7. #5
    May 2011
    Alexandria, VA
    512
    Yea, I should have known better.
  8. #6
    Jan 2015
    Simi Valley, CA
    1,783
    If all else fails, spray a microfiber with the 303 product and wipe the entire screen with it. Doing this may result in a albeit altered finish, it should at least be uniform.
  9. #7
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by 2black1s View Post
    screen with it.
  10. #8
    Sep 2020
    Eastern PA
    1,792
    here's 303's solution for glass. i wouldn't use a brush on the plastic. maybe soak a microfiber in warm water until it warms up, wring it out and then use that?
    How do I remove 303 Protectant that has accidentally been over-sprayed on glass?
    To remove the cloudiness on the glass, we recommend the following steps…
    1.) Put hot water on cloudy surface, the hot water will strip the Aerospace Protectant off the surface. Be very careful when handling!
    2.) You may have to agitate the surface. Use a soft brush or something that won’t hurt the surface.
    3.) Wash off with soap and water.
  11. Thanks 57Rambler thanked for this post
  12. #9
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    Quote Originally Posted by MisterSnoop View Post
    I would slightly alter that process for a surface such as the "screen" noted by the OP.
    1. Do not use overly "hot" water as that might lead to condensation behind a "screen".
    2. In lieu of a brush, I'd use a suede MF made for screens to agitate (scrub) the surface lightly. Only kind of brush I'd use on that would be a HQ boar's hair.
  1. Replies: 25
    Last Post: 05-30-2020, 10:22 PM
  2. Mud stained interior plastic
    By Zee19 in forum Auto Detailing 101
    Last Post: 11-07-2017, 05:41 AM
  3. My screen name is now for real!!!
    By WRAPT C5Z06 in forum Off-Topic
    Last Post: 08-13-2015, 09:17 PM
  4. Discolored/ stained plastic
    By BLyons in forum Auto Detailing 101
    Last Post: 05-27-2011, 02:40 PM
  5. Car at the top of the Screen
    By belcherm58 in forum Off-Topic
    Last Post: 09-24-2009, 02:28 PM
