Re: Your favorite Car Wash Soap
The honeydew snow foam is currently what i am using. I have used better, but it's not a bad soap. I would probably not get another gallon. Just better choices for a foam gun. I found it a bit lacking in the foam area and clinging to the paint.
Duragloss 902. $34/128 oz or $3.76/oz.
I use maybe 4-6 oz per wash in my foam gun on the 4th proportioner setting.
Love the results.
Yes! Duragloss is great via foam gun too
Originally Posted by
Paul A.
Love the results.
What do you like about it ?
How do you feel it handles water spotting issues on hot days ?
I have a small bottle of it. It seems like nice soap. Just not enough volume of uses to get a grasp on how it handles washing in the heat.
Gosh, favorite? Im not sure I have one. I certainly like some better for foam cannon and others better for a strip wash VS coated car wash.
CG Citrus Wash & Gloss
Adams car shampoo
CG Honeydew
Meguiars D111
"Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...
aim4squirrels
Megs Hyper seems to be the AG favorite based on what I'm seeing here. I'll have to try it. I've always used Meg Gold Class or GG Brilliant. Since I've used TW Power-Wash, at a higher pH level, I've noticed better cleaning, at the cost of lightly degrading the protection on my car I assume.
Ducksfan, trust me...it sees heat and direct sun in Tampa but i've never had it spot or streak after drying.
I should clarify. I always keep ALL sides wet when I'm washing i.e. no panel dries. I then use the drip method for every customer with an LSP.
I like how it leaves nothing behind. Just clean paint.
Meguiars NXT has good cleaning ability.
Paul A.
Love the results.
It's actually around 27 cents an ounce.
When I saw $3.76 an ounce and you use 4-6 ounces you'd be almost 20 bucks a wash. Uffda.
That's a good price BTW
DUBL0WS6
I haven’t seen it in YEARS. Where have you found it? I need it. That smell!
2017 Jeep Wrangler Unlimited Rubicon
1999 Camaro Z28
DFB liked this post
