Results 1 to 5 of 5
Thread: Tar removal
    Super Member joleyred's Avatar
    Dec 2015
    Nunica, Mi
    270
    Tar removal
    I applied Carpro UK to my truck in the fall. Today, I was detailing the truck and had a few stubborn tar spots. I considered using IGL Ecoclean tar remover, which is a creamy tar remover that works pretty good. I think the IGL might remove the coating, but I'm not sure. Anyone have any thoughts on this?
    Thanks, Tim
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Tar removal
    Tar removers are solvent/petroleum based and will remove some if not all of your coating. I would clean and re-coat.
    Regular Member crg001's Avatar
    Oct 2020
    Redlands CA
    171
    Re: Tar removal
    CarPro's Tar-X should be safe to use on the CQUK coating for contamination removal. I've used it on my CQuartz classic coated car without issue for tar and sap removal. I would wash really well with Reset or a strong soap afterwards and maybe top up with a SiO2 detailer/sealant like Elixer or Reload, or whatever similar product you have on hand, just to feed the coating a bit and keep the hydrophobics in top shape.
    Colin Lang
    @DimensionalShine <- My Detailing IG Page
  4. Likes dwaleke liked this post
  5. #4
    Feb 2019
    66
    Re: Tar removal
    Another option for a tar remover that is listed as coating safe would be Gtechniq W7. I have used it successfully on Gtechniq coatings, but I really don't have the need to use it hardly at all nor have I used it with CQuartz UK. It does have a strong odor to it, definitely wash your towels well after use.
  6. #5
    Super Member dwaleke's Avatar
    Nov 2009
    226
    Re: Tar removal
    As was said above. CarPro Tar-X is safe to use as-needed on a CQUK coated vehicle.
    But as Mike always says if a product isn't adding to your protection then it is doing what? So just use it as needed - don't get carried away.
  1. Replies: 0
    Last Post: 07-23-2017, 12:41 PM
  2. Replies: 9
    Last Post: 06-17-2016, 10:31 AM
  3. BMW Tar removal
    By Detailing by M in forum Auto Detailing 101
    Last Post: 08-29-2013, 11:06 AM
  4. Water spot removal or swirl removal?
    By A.P.A.D. in forum Auto Detailing 101
    Last Post: 12-09-2011, 12:46 PM
  5. Wheel Weight Adhesive Removal & Wheel Scratch Removal
    By tenorplayer23 in forum Auto Detailing 101
    Last Post: 10-24-2010, 03:16 PM
