Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Super Member vaca22's Avatar
    Feb 2020
    380
    So, what is the deal with Meguiar's D2002 (Iron Removing Spray "Clay")
    This appears to be 1 of 4 products (that I've noticed, at any rate) from their Detailers line that have popped up at chain stores.
    It seems like iron removers are challenging to find without having to be ordered online. Sometimes I'd juat like to walk into a plce and pick one up.
    Does anyone have any experience with this product?
    Super Member vobro's Avatar
    Jun 2012
    Homer Glen Il
    1,156
    Re: So, what is the deal with Meguiar's D2002 (Iron Removing Spray "Clay")
    Works pretty good, just slower than IronX. I like to buy as needed because I had a real sensitive sense of smell (pre Covid) and these type of products would really stink up the garage and I also had a bottle disintegrate and it was a real disaster. The only negative I had with the Megs was the spray tip sucked right out of the box, I cleaned it after use and it was still bad
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    •Basically:
    -The Clay-ing process removes contaminates
    that are bonded to the paint.
    •On the other hand:
    -Isn’t Meguiar’s D180101 Wheel & Paint
    Iron Decon
    the product to use, when you
    want to “remove iron”?
    {Or perhaps you’re talking about
    Meguiar's Iron Removing Spray
    #DRTU200232
  4. Likes PouncingPanzer liked this post
  5. #4
    Jun 2012
    Homer Glen Il
    1,156
    •Basically:
    -It’s my understanding that Meguiar’s
    product #D200200 is a Clay-ing Kit.
    •On the other hand:
    Iron Decon
    #DRTU200232
    The D2002 is an iron remover that can be also used as a clay lube, confusing right?
  6. Thanks PouncingPanzer thanked for this post
  7. #5
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by vobro View Post
    •And on top of that, Meguiar’s doesn’t
    recommend using it as a Clay lube for
    any of their Professional Clays (C2000;
    C2100).
    -It’s OK using it with the Clay pad in the
    G200200 Clay Kit, though. Say Whhaaat?!?!
  8. #6
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,230
    You would have to be nuts to use that as a clay lube, even though what bob said is true per directions. It says right on the bottle...Do not allow product to dry. Which is almost impossible to do when claying.
    I have tried a bottle of it, it works. I have a gallon of adams now and thats all ive ever tried so far.
  9. #7
    Super Member Farmallluvr's Avatar
    Jul 2018
    Michigan
    507
    I picked up a bottle of Sonax Iron decon at Advance Auto 2 weeks ago,,what a repulsive smell but it worked pretty well,,not something i'll use when I am worked indoors during the winter though
    “I have trouble with names and faces, but I never forget a car.”
  10. #8
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    Quote Originally Posted by opie View Post
    HOW is it "impossible" to not let it dry while claying? lol You spray a panel, let it dwell then clay it and rinse off. Then move to the next panel. Not sure why you said IMPOSSIBLE?
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  11. Likes John U liked this post
  12. #9
    Mar 2021
    Pa
    2,230
    Quote Originally Posted by dcjredline View Post
    For me it dried quick. So trying to use it as a lay lube it would dry on the surface before being able to finish the steps you had mentioned. Directions said to not let dry on the surface. Just my experience with it. Yours may be diff than mine
  13. #10
    Feb 2020
    380
    Massive thread bump!
  14. Likes opie liked this post
  1. Replies: 11
    Last Post: 03-26-2017, 09:48 PM
  2. Replies: 5
    Last Post: 11-27-2014, 05:14 PM
  3. Replies: 8
    Last Post: 09-25-2013, 08:53 AM
  4. "Where to clay" indicator spray
    By SR99 in forum Auto Detailing 101
    Last Post: 08-27-2012, 09:50 AM
  5. Replies: 2
    Last Post: 04-04-2012, 09:43 AM
