Quick Detailer Spots on Glass
Hi!
Well, I just finished polishing my first ever car, and I think it turned out pretty good. Made a stupid mistake though that I am hoping won't be too bad to fix.
I used a QD while I was claying the car, and after claying, I did not rinse it off. Haven't been driving the car and didnt really realize that this could be an issue, but now on the side of the car that I used this QD, I have these water spots that regular glass cleaner isn't touching. I can feel them with my finger/nail. Was not planning on polishing the glass yet, so was hoping to see if there is any chemical or anything I can do to get these off?
I know some water spots can be hard to get off glass, and there are polishes specifically for glass for that, but I am hoping since this was a QD leaving these behind, I can use something else to break that up?
Any ideas?
I have a bit of cut max left, so I guess if need to I can just try to hit it with a microfiber pad and some sonax cut max but hoping I wont need to do that.
Thank you!
Re: Quick Detailer Spots on Glass
What QD are we talking about? Hard to see a QD leaving spots that can be felt by touch. They’re usually so diluted there’s not enough solids for that. Maybe if it’s a high SiO2 formula but then you shouldn’t have used that as clay lube.
Probably spray the spots with the same product and clay the area, should remove them, otherwise you might need to polish the glass.
I am pretty sure it was Pinnacle XMT Final Finish Instant Detailer that I bought in 2009.
Let’s see if someone that has used that product can chime in. I have never used that one but I still don’t think it can be leftover product, something else must have fallen on the glass and got stuck to it.
Originally Posted by
Bruno Soares
Well fortunately just claying the glass took care of it. Like with other surface contaminants I could feel the stuff coming off the glass as I was claying amd now the spots are gone! Thank you for the suggestion!!! Appreciate it!
Like Bruno said. In a situation like that, using the same product to remove is generally going to be your best first move.
