Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jun 2021
    Thumbs up Super hazy headlights after restoration 🤔
    Hey guys, new member here. I tried searching this topic but didn't find any helpful information. Just a few older threads. Hopefully this is the right place to post. Any and all suggestions are greatly appreciated.
    I have restored plenty of headlights in the past and this is the first time that I've really encountered this "issue". The vehicle is a 2003 Nissan Maxima. I started off using the 3M headlight restoration kit then added a variety of different sanding disc. I started with 500 grit (included in 3M kit) then progressed up to 2500grit and 3M Trizact 3000 pad. Polished with Meguiars 105 and also tried Meguiars plastic X. The lense itself is free from scratches or major defects. It looks okay but doesn't have the clarity that it needs to have. Hopefully the picture shows up below. Please let me know if you guys have any suggestions on what I can do to make these "pop". I hate the hazy look.
    Before:
    After:
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: Super hazy headlights after restoration 🤔
    Are you polishing by hand or machine?
    Jun 2021
    Wet sanding was done with cordless drill, polishing done with both drill (foam attachment included in kit) and DA polisher with microfiber pad.
    Super Member TTQ B4U's Avatar
    Jan 2016
    Central Ohio
    5,438
    I've done plenty but have never sanded with below 1000 grit. IMO it's more trouble than it's worth when it comes to then refining them. I'd likely give it another go with 3000. They should eventually prove far clearer than this and then a final polish (I use Rolite brand polishes) will bring them to near 100%.
    I wouldn't stress too much as once you hit them with Meguiar's G17804 Keep Clear Headlight (4oz spray can) even what you show here will come back to clear.
    2023
    Nov 2015
    Los Angeles, California
    13,765
    I’m not sure exactly what year this Nissan Maxima was, but when I tried polishing the headlights they didn’t budge one bit. I’m talking zero change. So I’d say it has less to do with technique and more to do with Nissans from that era having cheap headlights.
    And IME that Meguiars spray will not fix headlights that behave like this. I’ve tried it on my fathers Tacoma and once the plastic turns yellow all the way through there’s no fixing it.
  6. Thanks Zcutty69 thanked for this post
  7. #6
    Aug 2013
    St Louis metro (Illinois)
    5,809
    This thought goes in the same direction I was thinking too. I think there is a point in time where the hazing/discoloration is IN the plastic itself (or maybe the interior surface) and no longer an external surface issue.
    I've been polishing the headlights on my daughter's Mazda for a few years now. One thing I noticed the last time is I can still get them really clear/new looking, but there are slight hints of cloudiness which appear to be either in the plastic itself or on the inside of the lens. You have to get really close and know what your looking at, but it's there and I'm confident it wasn't there in the past.
  8. Likes Eldorado2k, Zcutty69, oneheadlite liked this post
  9. #7
    Nov 2015
    13,765
    These cheap license plate covers serve as the perfect example of that cheap plastic where that happens. I used to have several of these that showed the effects of that longterm sun damage and they turn yellow all the way through. I can’t remember if they finally got tossed or where they’re at right now.
  10. Likes Zcutty69 liked this post
  11. #8
    Jun 2021
    Greatly appreciate the input guys. I honestly think it's the plastic itself the more I think about it. The exterior surface of the lense is pretty much perfect. Also forgot to mention but I did use the Meguiars "keep clear coating" and it didn't make any difference besides adding just a bit of gloss to the surface. The headlight still looks hazy.
  12. #9
    Jan 2016
    Central Ohio
    5,438
    Quote Originally Posted by Zcutty69 View Post
    Then it's definitely on the inside or the plastic itself. I'd look at removing an assembly and swishing denatured alcohol around inside them to see if the haze is just from build up over time. If not at least you ruled that out. Worst case, look into simply replacements.
    2023
  13. Likes Zcutty69 liked this post
  14. #10
    Jun 2021
    Yeah I'm looking into aftermarket replacements now. I might also open one up and try to clean the inside lightly with alcohol. Now can the inside of a headlight be sanded or polished at all ?
  1. Headlights restoration
    By Monsterdetail in forum Auto Detailing 101
    Last Post: 11-11-2018, 10:03 AM
  2. Headlights restoration? What is ur method?
    By EvolutionDetail in forum Auto Detailing 101
    Last Post: 03-30-2014, 02:26 PM
  3. Replies: 9
    Last Post: 08-11-2010, 02:33 AM
  4. Can you use a PC 7424XP to restore cloudy, hazy headlights?
    By ballfan4141 in forum Auto Detailing 101
    Last Post: 05-20-2010, 08:45 AM
  5. Two Guy's Garage Video: How to restore clarity to cloudy, hazy yellowed headlights
    By Mike Phillips in forum Autogeek on Velocity Channel TV
    Last Post: 05-07-2010, 04:57 PM
