After Polish Is IPA Wipe Down Good Enough [ Vs Rewash + IPA Wipe Down]
First time I will be applying ceramic.
Does IPA wipedown remove polish remnants/oils fully (looking at using 20% ipa wipedown solution).
Or even with a good IPA wipedown can some polish remnants/oils still linger to a certain degree.
Crazy part of me is saying to do a re-wash + ipa wipedown after polish. Sane part of me is saying quite inventing extra unnecessary steps.
Re: After Polish Is IPA Wipe Down Good Enough [ Vs Rewash + IPA Wipe Down]
You don’t need to rewash , an IPA wipe down will work however I would make it a 40% alcohol IPA or even 50%… That being said putting on a coating is a semi permanent experience, and only one you do once or twice in the lifetime of the car. Because of that, I would probably get the prep product made by the coating manufacturer. Carpro eraser is a good one.
Without addressing coating prep in general as I have zero experience there, if I were in your shoes, with your concerns, I'd just wash the car first.
Even if it's not absolutely necessary, it certainly can't hurt and you'll have the peace-of-mind of not skipping something you think could be beneficial.
If you do rewash, (which I don’t this is strictly necessary), make sure your soap has zero remnants left behind. A lot of soaps have ‘gloss enhancers’ that I think would interfere with the coating. The IPA should remove them but it would be a fresh layer of whatever. Plus you’ll have the surfactants to deal with. Overall, I think you’re making a lot of work for no gain.
Originally Posted by
Fallguy007
You just answered your own question lol
Fallguy007
•IMO:
(In order to have assurance of an overall
successful Ceramic Coating application):
-Follow the Ceramic Coating manufacturer’s
“prep” instructions—yes, this includes
their recommended panel-wipe.
-By doing so will take away the confusion
and/or anxiety over what products/processes
to use.
Fallguy007
Which coating? The risk of rewashing is the potential to put back scratches into the freshly polished surface. When in doubt as a well known professional has stated to use the intended panel prep for that particular coating.
No need to re-wash. I don't personally use an IPA, I use more consistent and safer true panel wipe product either from the manufacturer. Something Like Optimum Paint Prep works well too though. This particular brand doesn't have any anti-static agents which could interfere so it works well. Washing will also re-introduce water into joints and trim pieces that will need fully dried prior to coating (for best results) thus as a detailer it would cost me time. YMMV though.
