Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Mar 2017
    Louisiana
    197
    Need help with rubber window trim 2004 Sienna
    I am wondering if anyone has a method to clean this trim up. It looks to me as if the finish is no longer there. I have tried Mothers VLR and it did nothing. I tried Gyeon Trim and it also did nothing. I was going to try a heat gun but figured I’d ask for some help on this one. I did read brake cleaner could help, or even engine treatment products like Lucas could help. Any ideas would be helpful and appreciated.
    I cleaned the glass but can’t seem to get rid of the white specks next to the rubber gasket. It seems like the are etched into the glass but the glass feels smooth.
    Mar 2017
    Louisiana
    197
    Re: Need help with rubber window trim 2004 Sienna
    Does no one have any suggestions?
    Jan 2015
    Simi Valley, CA
    1,783
    Looks like a build-up of mineral deposits on the glass. I'd remove it with a single edged razor blade. You could also try something like "Lime-Away" or "CLR" but if you do be sure to test for compatibility with the surrounding surfaces.
    For the trim, if it is plastic/rubber, I would try cleaning with the same "Lime-Away" or "CLR" followed by lacquer thinner. Again, test for compatibility. Then apply a protectant or sealer. If it's metal trim, then I would try a fine polish or AIO followed with a protectant or sealer. If that doesn't work then I would repaint it with a matte or semi-gloss rattle can.
    Super Member LEDetailing's Avatar
    Jan 2016
    Wisconsin
    1,729
    Sorry for the crummy photo. Screenshot taken from a video. (Left prior to cleaning, right cleaned)
    I cleaned my parents 2009 Toyota Sienna window trim with HD Speed polish (by hand). Sounds strange but I’ve had the same luck cleaning rubber with rubbing compound. Use a microfiber or if MF doesn’t cut the crud off, try a stout fiber terry cotton towel.
    Jan 2016
    Wisconsin
    1,729
    Mar 2014
    Melbourne, Florida
    232
    I have the same thing going on with my car. I think it may be oxidation. I've tried several recommendations but nothing has worked yet.
    I heard that Solution Finish will remove oxidation.. that is what Chris West said. I got a bottle the other day and applied it to my very weathered plastic cowl and it did an amazing job at restoring it. I've tried so many things and nothing worked but so far Solution finish has made it look new again. I have yet to try it on my window rubbers/dew wipers but I will be trying it soon to see if it will restore them.
    Mar 2017
    Louisiana
    197
    Quote Originally Posted by LEDetailing View Post
    Looks good. I will try. Thanks.
    Mar 2017
    Louisiana
    197
    Quote Originally Posted by 2black1s View Post
    I never thought about clr. And like always when I’m looking for my bottle of clr...that I haven’t used in a few years I can’t find it.
    I figured I would try the clr then polish it like LED did. Thanks.
    Mar 2017
    Louisiana
    197
    Quote Originally Posted by jem7sk View Post
    Thanks for the solution finish recommendation. I hadn’t thought of that one. I guess my first thought is to try to repair (clean my way to a new finish) but I may need to go this route.
  10. #10
    Super Member Shane731's Avatar
    Dec 2009
    Madison, AL
    3,498
    Shane
  1. Question about cleaning rubber window trim
    By Eldorado2k in forum Auto Detailing 101
    Last Post: 01-26-2016, 04:25 AM
  2. Rubber window trim
    By sledhead1 in forum Ask your detailing questions!
    Last Post: 03-03-2014, 09:49 AM
  3. How do you clean up rotted rubber window trim?
    By natt2000 in forum Ask your detailing questions!
    Last Post: 12-31-2012, 06:55 AM
  4. Rubber window trim
    By bodavenport in forum Auto Detailing 101
    Last Post: 10-12-2010, 08:13 AM
  5. Overspray removal on rubber window trim
    By 321sinned in forum Auto Detailing 101
    Last Post: 10-26-2009, 07:56 AM
