Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Super Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    3,340
    Re: CarPro Perl on Interior Trim Issues
    Ive never used it at 5:1, I use it at 3:1 usually and like PaulMys does I usually wipe with a dry towel to remove excess. Hope you figure it out
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
  2. Likes Coatingsarecrack liked this post
  3. #12
    Dec 2018
    7,171
    Quote Originally Posted by serper3 View Post
    Thanks. I will give it a try.
    I used P&S Xpress Interior Cleaner. Followed the instructions and went over it with a damp microfiber. waited for the trim to completely dry. saw a lot of people had good luck with PERL so not sure what my issue is.
    Apply P&S, wipe and then wipe again with damp cloth.
    I felt it was hard to get the P&S off so i tried it 1:1 with distilled as noted in instructions.
    I’m betting it’s the P&S residue.
  4. #13
    Apr 2021
    34
    I don't have to use the P&S cleaner every time though right? I can just use a dry microfiber to get the dust off and apply another coat of PERL to try to "fix" it? this time spraying it on a microfiber and then on the trim.
  5. #14
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    400
    On my wife's 2019 Rav4 (lots of black trim outside), Perl will look streaky after some weather hits it. I haven't used it on the inside of my cars before. Under the hood and on the shaker seal of my Mach 1, it hasn't shown any streaks that I've noticed. I'm use it diluted 50/50. I figured the next time I apply it on trim outside, I'll use less. I'm kinda thinking in my case, I may have put it on too heavy on my wife's car.
  6. #15
    Apr 2021
    34
    Yea I think I might have put it on too heavy too. I wonder if going back with a dry microfiber to pick up any excess after initially applying would help.
  7. #16
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    You could always follow up with a damp towel and see if it helps to level it.
    Next time spray into your microfiber towel or applicator and apply it. Come back with a second one to level it out.
  8. Likes robwoodgto, Azure liked this post
  9. #17
    Apr 2021
    34
    Thanks! I will try that out and see how it goes.
  10. #18
    Feb 2018
    I had exactly the same issues, we have a black interior in my wife’s car and I used a 5:1 ratio. I sprayed it on a microfiber towel and it came out with “splotches” all over. It looked horrible. I used a wet towel to level it out and fixed it. Looks good now
  11. #19
    Dec 2018
    7,171
    If you wanna remove old layer you can clean but i would just top. I use an interior QD to maintain myself.
  12. Likes DFB liked this post
  1. CarPro PERL issues... Help Please!
    By Swiss_T in forum Auto Detailing 101
    Last Post: 09-28-2019, 02:43 PM
  2. Issues on Polishing Interior Black Piano Trim
    By spielwurfel in forum Auto Detailing 101
    Last Post: 07-07-2018, 06:31 PM
  3. Replies: 26
    Last Post: 08-18-2016, 03:18 PM
  4. How do I remove CarPro PERL from interior glass?
    By y8s in forum Tricks, Tips and Techniques
    Last Post: 11-26-2012, 03:01 PM
  5. Issues with Carpro perl
    By stephent007 in forum Ask your detailing questions!
    Last Post: 11-04-2012, 11:12 AM
