Results 1 to 8 of 8
    Super Member bob m's Avatar
    May 2009
    Glen Ridge, NJ
    294
    Quick question on engine/engine bay cleaning
    I know most modern cars have engines that are supposed to be shielded from water damage and by that I am referring to a quick hose wash/rinse, not getting stuck in a flood. I'm thinking of cleaning via pressure washer my engine/engine bay. Anyone experience any damage from doing so, is it a safe way to do the job?
    Mar 2011
    PA
    5,815
    Re: Quick question on engine/engine bay cleaning
    I only use low pressure from a garden hose. Sprinkler attachment. I would not high pressure wash a engine.
    2018 Colorado ZR2
  3. Thanks bob m thanked for this post
    Likes Klasse Act, SANTA3013 liked this post
  4. #3
    Mar 2018
    Conroe, Texas
    477
    I use my pressure washer as the rinse process with a 40-degree or 25-degree tip. I do keep it at least a couple of feet away from the surfaces. Use it with care and never close to any fuse box nor alternator. Use it on my Lexus and a few F150 engine bays. Afterwards start the engine and run to warm up and dry things off.
  5. Thanks bob m thanked for this post
    Likes robwoodgto liked this post
  6. #4
    Super Member UncleDavy's Avatar
    Aug 2017
    Taunton, MA
    1,595
    Low pressure water would be best. I always cover the alternator with a plastic bag.
    I believe in treating everybody with respect, and clean cars. That’s what I believe in.
  7. Thanks bob m thanked for this post
    Likes DFB liked this post
  8. #5
    Super Member Hermes1's Avatar
    Sep 2014
    Nomad, wherever we park our rig
    255
    I have only used a garden hose for rinsing. Prior to washing all I cover are a couple of the sensors with aluminum foil. I have not covered the alternator in years.
    Sincerely, Bruce
    2015 Ram Big Horn CC 3500 Cummins DRW w/AISIN tranny
  9. Thanks bob m thanked for this post
  10. #6
    Junior Member BurnsDetailing's Avatar
    Jun 2020
    52
    We use our Kranzle PW for engine bay cleaning on all of our used car reconditioning and for detail clients. Never had an issue come of it. PW caps out at 1400 PSI, we only use the 40-degree nozzle and we still keep the gun a few feet away from the engine.
    Just check the engine over before cranking for signs of water pooling, like the early 2000s Ford Zetec engines where the ignition coils sat in a U-shaped trench in the valve cover with no way to drain. Wet vac out any standing water, then crank.
    Fuse blocks, alternators and underhood electrics in general have come a long way in the last 30 years, as you will notice most modern vehicles barely have an air deflector, let alone a splash guard to seal from water coming from underneath anymore, unless it's a performance car or vehicle with off-road intentions.
  11. Thanks bob m thanked for this post
  12. #7
    Super Member SANTA3013's Avatar
    Dec 2008
    698
    I probably go to the extreme but that’s just how I roll. I cover anything that could get water in it. I also remove the battery and clean it up before reinstalling it. I do not use any high pressure water or even a water hose to rinse. I used Purple Power cleaner and an assortment of brushes. I used a hand held pump sprayer bottle with water to rinse everything off. I recently purchased this’08 Tacoma with 413,000 miles from the original owner and this is the before and after pictures. Yes it took several hours but not once was I concerned about water going where it shouldn’t.
    2008 Toyota Tacoma 410,000 miles and still going strong.
  13. Thanks bob m thanked for this post
    Likes dennis b, Prange, DFB liked this post
  14. #8
    Sep 2016
    381
    I also use a hand-held sprayer. And no harm done by masking.
  15. Thanks bob m thanked for this post
    Likes SANTA3013 liked this post
  1. Question about cleaning engine bay
    By mrq0604 in forum Auto Detailing 101
    Last Post: 04-22-2019, 03:18 PM
  2. Replies: 6
    Last Post: 12-31-2016, 11:30 AM
  3. Replies: 17
    Last Post: 10-12-2016, 09:53 PM
  4. Quick Engine clean up
    By sharpreflection in forum Auto Detailing 101
    Last Post: 08-09-2013, 07:30 PM
