Re: First large order, any input?
Originally Posted by
Mallowpuff
I'll look at those pads.
I was also looking at the 3D stuff, they looked great but since it advertises itself as an all-in-one type compound/finish, I assumed it was a gimmicky product. However, I really only hear positive things about 3D Products.
I switched from Menzerna to 3D one. Its not a gimmick. The product gives me great flexibility with my collection of machines and pads. Regardless of which liquid you chooses... it takes practice and patience to learn the techniques to take full advantage of all its capabilities.
psnt1ol
Did you take a look at my pictures? In your opinion, would 3D One with an aggressive pad be able to work on that? Then down to a polish pad or something. Because a one step liquid thing sounds very nice to me.
Mallowpuff
3D ONE might work with a less aggressive pad. Those swirls in your pics are very minor.
Always start with the least aggressive pad/product, and if that does not give you the results you are looking for, then step up the levels of aggressiveness.
PaulMys
Sounds good. I think I'm going with 3d One. I'll get a variety of pads from light cutting to polishing.
Mallowpuff
Sounds good.
The hardest part of this whole process is deciding which products to try first. There are so many options, but only you can decide in the end.
And, only you will be able to tell if they are working for you once you put the pad to the paint.
Mallowpuff
To be honest... its hard for me to make that determination from just looking at those 2 pics. The paint looks dull and I couldnt tell if it is swirl out. It doesnt look that bad from what I saw. Do a test spot prior to confirm your approach. Mazda as well as most Japanese brands generally have soft paint so I think it should work.
3D One is pretty capable. Its little cousin 3D Speed (AIO-polish and wax) is a product I used a lot for a One Step (polish and wax) when the budget doesnt call for a multi-step correction.
Here is a range rover I did a few months back (3D Speed with a orange LC forced hybrid pad on a gear driven DA).
2018 Range Rover Evoque....
to OP...
I didnt mean to cause any more confusion by throwing another product in t the mix. I just want to make the point that there is more than one way to skin a cat.
psnt1ol
Yeah I was considering the multipack of HD Speed and ONE but after reading, I think I need to skip HD Speed because I am doing a ceramic coating. I mean I could go wax instead of ceramic coating as well..
Mallowpuff
You are correct about Speed. No need to lay down a layer of Montan wax that you have to remove before using a coating. That is working backwards.
But if you decide on using a wax or sealant, Speed is also capable of removing more defects than some people think. All depends on the pad(s).
Like I said.... There is more than one way to skin a cat. LOL
Regardless of which direction you are going with.... have fun doing it.
