Topping Sonax PNS with wax or topping wax with PNS?!
I really want to try out Sonax PNS and wondered if anyone topped it with wax to make it slicker? ...or maybe topped their wax coat with PNS?!
I just ordered Sonax Cutmax and 04-06 to do my car with this year (not sure if I'll need the Cutmax.) I wanted to try something else instead of the Meguiars Ultimate Wax or their Gold Class I've been using for years, so thought the PNS might be fun to try...
I've got Sonax BSD that I use time to time as well... Having a black metallic car is hard to make it really pop/gloss without it looking grey/silver...
Think I should try any of this or just stick to the all Sonax line this year on my car?!
Thanks
Re: Topping Sonax PNS with wax or topping wax with PNS?!
Originally Posted by
Icarus
to make it slicker?
Icarus
From my experiences...I’ve never had
Waxes make Sealants “slicker”.
But that, in no way, does not preclude
you from experimenting with various
types of finishing LSPs as you deem fit.
FUNX650
I read so much on PNS not being 'slick' hence my questions :/
And I meant topping with wax wax, not a LSP...
Icarus
Isn’t an LSP the product that is
applied during the last step of
the Detailing process?
If so:
Then aren’t Waxes/Sealants/Coatings
prima facie examples of LSPs?
FUNX650
If so:
I've always put wax on last.
Unless its just a quick clean between polish/wax/coating...
I polished my daughters car with sonax 04-06 March 2020. Applied PNS, waited 24 hours and topped with BSD. 6 months later the car was beading water like I just applied it. Jump ahead to this past weekend, I washed car and applied another coat of BSD. Still beading water very well. Not the slickest combo I’ve used but, can’t beat the durability unless your applying a true coating.
FUNX650
If so:
Whoops my bad, I thought LSP was liquid spray products (like quick detailers etc), sorry! doh!
I've got some Sonax PNS on the way, as well as some other goodies
Prepare yourself for Polymer Net Shield! Definitely one of the best sealants in terms of hydrophobic staying power, but let me warn you about how terrible the wipeoff can be in some situations to fully level out. Don't go too far before wiping it off the paint and work in small sections. Ultimate and Gold Class are pretty much a dream to work with in comparison.
I would avoid topping PNS with anything heavy like a paste or liquid wax, those will just cover up that great performance. If you're trying to boost the slickness, you're likely to loose some of that top notch beading in the process. Even something lighter like Bead Maker that might play well on some coatings can reduce that tight beading of PNS. I would recommend sticking with BSD for maintenance, but eventually I would like to test how the new Sonax Ceramic Spray Coating and Ceramic Detailer would do on top of PNS.
You can top PNS with any sealant or wax that has the slickness properties you are looking for, including quick detailers.
