Results 1 to 9 of 9
Thread: Rupes PadS
    Super Member DETAILROOKIE's Avatar
    Jan 2016
    1,158
    Rupes PadS
    Happy St. Patty's Day!!
    I received my Rupes Yellow pads and they have this Red stain from the Rupes logo on them. I tried cleaning it to remove the stain, but nothing works. Will this ruin the pad? Anyone else experience this?
    Not sure why would put a Red logo that leaks on the back of a pad, seems odd.
    Thanks in advance!
    Sent from my SM-N960U using Autogeekonline mobile app
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Rupes PadS
    That happened to mine too when I was soaking them... I'm not worried about it.
    But I agree, a more colorfast dye should be used.
  3. Likes DETAILROOKIE liked this post
  4. #3
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: Rupes PadS
    Quote Originally Posted by DETAILROOKIE View Post
    Thanks in advance!
    That seems excessive. I've seen a ton of Rupes pads and normally there is just a slight red bleed through.
    It should not hurt the performance of the pad, but I know what you mean, you bought a new pad and got a blemish. Not cool.
  5. Likes DETAILROOKIE liked this post
  6. #4
    Jul 2014
    246
    Re: Rupes PadS
    Thanks in advance!
    I would contact them to make sure they are aware of the problem. I had to do same with Chemical guys trigger on a a few bottles I bought.
    Sent from my SM-N986U using Tapatalk
  7. Likes DETAILROOKIE liked this post
  8. #5
    Mar 2017
    Southeastern PA
    2,480
    Re: Rupes PadS
    They do bleed through, yours seems like a lot but I think it will be fine, soak it a bit and wash it and most of the red dye will go away.
    Bruno Soares
  9. Likes DETAILROOKIE liked this post
  10. #6
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Rupes PadS
    Well, you can easily identify your Rupes pads from others now, Leo.
  11. Likes DETAILROOKIE liked this post
  12. #7
    Jan 2016
    1,158
    Re: Rupes PadS
    Thanks everyone! I call and see what they say. I let it soak in Mckees pad cleaner and nothing. I hope it doesn't hurt its performance .
  13. #8
    Re: Rupes PadS
    Just to chime in....
    That type of staining or discoloration is nothing. There's nothing to be worried about.
    I wouldn't hesitate to use that pad on ANY detailing project. Just make sure it's clean in that there's no surface dust or contaminants and go for it.
    I would say the majority of pads in our garage are stained from YEARS of use and abuse and until the velcro backing is coming off we just continue to use them.
  14. Likes Goonie75, DETAILROOKIE, fly07sti liked this post
  15. #9
    Aug 2013
    St Louis metro (Illinois)
    5,809
    Re: Rupes PadS
    Sounds like about half my pad inventory. Wolfgang Total Swirl Remover or the old Blackfire's old SRC polish, which are purple liquids, stained almost all of my white LC pads and they are now a strange gray color.
  16. Likes DETAILROOKIE liked this post
  1. Replies: 24
    Last Post: 01-03-2020, 11:12 AM
  2. Rupes polisher, Rupes pads, non Rupes polish
    By joleyred in forum Auto Detailing 101
    Last Post: 05-27-2018, 10:18 PM
  3. Rupes polishing pads and Rupes compounds confused
    By Crispy in forum Ask your detailing questions!
    Last Post: 07-01-2016, 01:44 PM
  4. Recommended pads for Rupes mark ll and Rupes mini
    By Elger in forum Wool & Foam Buffing Pads
    Last Post: 06-21-2016, 09:32 AM
  5. Rupes bigfoot 100mm foam pads on Rupes LH18ENS rotary
    By rah28 in forum RUPES BigFoot Oribital Polishers
    Last Post: 01-04-2016, 07:17 AM
