Results 1 to 9 of 9
    Jul 2017
    Carbon Fiber Cracks
    Hello everyone,
    I was looking over my carbon wing and noticed some cracks. I was wondering if any of you had experience with repairing carbon fiber. I can’t tell if the cracks are in the coating or fibers. Also, is it likely that the cracks will spread if I don’t repair them? If possible, I would like to repair the wing because a new one is about $1300
    Thanks
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,897
    Re: Carbon Fiber Cracks
    Your CF wing has a clear coat on it...
    If it is cracked, it would need to be sanded down and re-cleared I'm afraid.
    Scott Harle
    Autodermatology
    #autodermatology
  3. Likes DUBL0WS6, The Guz liked this post
  4. #3
    May 2013
    TN
    1,768
    It doesn’t look like a crack in the carbon fiber so much as the outer coating. Usually carbon fiber (composite) is done with epoxy or similar resin and it looks like the coating isn’t handling the flexing. Not sure why there would be a crack or flexing in the second picture so maybe that’s a scratch? The first picture shows a joint and I’m sure there is some flex there and the coating isn’t handling it. I’d recommend looking at an epoxy coating that can handle some flex. The problem is, I’m not sure how you’d repair it to make it invisible. You’d really need to figure out the coating so you can get something that would chemically bond with the existing coating and hopefully be an invisible fix. But the repair definitely needs to handle some flex.
  5. #4
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    I made custom subwoofer enclosure with carbon fiber skin as well as carbon fiber car parts in my younger days. I dealt with hairline cracks on several occasions.
    You have to sand it down then reapply the resin. Generally, you would want to do 3 to 4 coats and wait several hours between each coat. After it cured...sand it till the repaired area is level to the surrounding area. It is just like fixing a touch up paint blob from this point forward. go through your progression of sand paper to around 2500 then polish with a DA.
    Its a long and slow process but when its done right...you could hardly tell it was there from a few feet away.
    The following vid would give you an idea on what I am talking about. Good luck.
  6. #5
    Dec 2018
    7,171
    Yeah those cracks looks like they are in the resin.
    Psnt is right and you may notice where you spot repaired but probably only you will notice.
    Second one on the end looks to be on a edge. Could be a scratch but I’m thinking stress scratch
  7. #6
    Jul 2017
    Carbon Fiber Cracks
    The crack in the second picture appeared randomly after sitting on my table for a couple of weeks. I haven’t been near the wing, which makes me think that it might be a stress crack. Will I have to apply clear coat to the new resin or does it act like clear coat?
  8. #7
    Aug 2012
    San Francisco
    892
    before you do anything... wet the area in question. While wet, see if the appearance of the cracks lessen. This is most likely how it would look after the repair.
    The only reason why you would add a few coats of clear is mainly for UV protection (so that the resin wont yellow as it age). You could accomplished this also with a coating that has UV blocker or a diligent sealant maintenance schedule.
  9. #8
    Jul 2017
    Quote Originally Posted by psnt1ol View Post
    I didn’t see a big difference after applying water to the cracks. So, would Cquartz UK prevent the resin from turning yellow?
  10. #9
    Aug 2012
    San Francisco
    892
    CQUK offers UV protection.
  1. Carbon Fiber Help
    By 03Mustanger in forum Ask your detailing questions!
    Last Post: 02-18-2020, 10:40 AM
  2. Red GTR with carbon fiber
    By donbeezy in forum Show N' Shine
    Last Post: 01-28-2017, 01:29 AM
  3. How to fix this? carbon fiber
    By randy00013 in forum Auto Detailing 101
    Last Post: 05-12-2013, 01:55 AM
  4. Some Carbon Fiber
    By Harleyguy in forum Show N' Shine
    Last Post: 04-15-2012, 05:52 PM
  5. Help with Carbon Fiber
    By PaPaHoFF in forum Auto Detailing 101
    Last Post: 03-11-2010, 11:23 PM
