Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
    Nov 2016
    253
    Re: Rinseless wash question
    Keep in mind too that some rinseless washes tend to have the dirt stick to microfiber more than others. Not sure how the new ONR performs but I know older versions were quite bad in this regard.
    Not a huge fan of rinseless washing but if I had to choose I'd go 2-bucket = sponge, single use wash media = towels or mitts.
  2. Thanks KBsToy thanked for this post
  3. #12
    Super Member Hermes1's Avatar
    Sep 2014
    Nomad, wherever we park our rig
    255
    I use edgeless 16" square micro fiber towels, soaked in the rinseless wash, folded in quarters. Years ago I used mitts but found them to perform less than good microfiber towels.
    Sincerely, Bruce
    2015 Ram Big Horn CC 3500 Cummins DRW w/AISIN tranny
  4. Thanks KBsToy thanked for this post
  5. #13
    Apr 2019
    Houston, Texas
    947
    Quote Originally Posted by Hermes1 View Post
    I use the same method but I keep a bucket with a gamma seal filled with 4 gallons of distilled water with the RW solution in the garage so I can wash the car if I get a wild hair!
  6. Thanks KBsToy thanked for this post
    Likes KBsToy liked this post
  7. #14
    Feb 2012
    Palatine Illinois, USA
    24,756
    Quote Originally Posted by glen e View Post
    Microfiber towels 350gsm-1 per big panel - for a mid size sedan I use 5-7.....Microfiber holds the rinseless so you have excellent lubricity when the towel is touching the surface- I have used mf’ s for 8 years.....
    Google/YouTube the “Garry dean rinseless method”.
    This just works....period Rinseless wash questionRinseless wash question
    2022 Elantra N Cyber Gray
  8. Thanks KBsToy thanked for this post
  9. #15
    Apr 2020
    Dayton, OH
    142
    I've gotten into rinseless washes lately, as I seem to be able to avoid water spots drying on my black truck better since you are essentially washing one panel at a time.
    As others have stated, I soak about 14 microfiber towels into a bucket for a good five/ten minutes before I start, and pretreat each panel with a waterless wash solution. Used towels go into a separate bucket for the wash. Then, I immediately dry each panel with a waffle weave microfiber.
  10. Thanks KBsToy thanked for this post
    Likes Klasse Act, oneheadlite liked this post
  11. #16
    May 2020
    400
    I tried rinseless wash for the first time this winter.
    I picked up some Griots Brilliant Finish Rinseless Wash (no Wax).
    I've washed my car 2x this year with it.
    Both times I ran to the DIY spray car wash and rinsed it with just the high pressure rinse to get the layer of sand/salt off the paint.
    I then drove home (~1/2 mile) and did the rinseless wash in the garage to get the film off the paint.
    I used 4 microfiber towels since it's a small car (VW Golf) and is fairly clean after the pressure rinse.
    I am impressed how clean the car is afterwards.
    Now if it would just get warm enough so I can wash it again (supposed to be a balmy -5F for a high on Sunday).
  12. Likes Klasse Act, KBsToy, bob m liked this post
  13. #17
    Feb 2012
    24,756
    ^^^^GREAT GREAT PRODUCT^^^
  14. Likes bob m liked this post
  15. #18
    Super Member BillyJack's Avatar
    Aug 2010
    Western PA
    1,227
    I've been doing 90% rinseless washes for the last ten years or so, using ONR, Meg's D114 or Duragloss rinseless. My favorite tool is a Meguiars Microfiber mitt. I wipe in one direction only, which picks up the majority of the dirt along and near the leading edge. Then make a pass in the opposite direction, which soils the opposite edge. Flip and repeat. That gives you 4 passes, after which I shake the mitt aggressively in the bucket to dislodge any dirt to fall below the grit guard. Primarily in the winter, when the car is laden with salt, I'll pre-spray with my rinseless solution from a pump sprayer.
    My DD is black and the only place I may have some noticeable fine swirls is the hood, which was previously a repainted panel and gets more wiping activity all year around, due to bird droppings and tree sap getting attention between washings.
    I've tried a few other MF mitts, including Blackfire and Griots, but the Meguiars seems to release the dirt in the bucket better than others and the bright white color doesn't hide any residual dirt.
    Bill
  16. Thanks KBsToy thanked for this post
  17. #19
    Feb 2012
    24,756
    Quote Originally Posted by BillyJack View Post
    Bill
    Watch his right footRinseless wash question
  18. #20
    Newbie Member Lone Wolf's Avatar
    Mar 2016
    You will be fine with either method. The yellow sponge is slightly softer than the red. The benefit of the BRS is that you don't end up using so many towels and is just as safe as using multiple towels. I have never experienced scratches with the BRS. Keep in mind that you are not scrubbing the surface but rather applying the solution. So expect to pick up a little dirt on your towel that the BRS does not pick up.
    A wash mitt also works fine. I have used rinseless washes with a microfiber wash mitt with no issues. And I have only used just one rather than multiple mitts with no scratching.
    Also the pre-spray method is a good idea. Simply take your spray bottle and dunk it into the rinseless wash solution you make.
    Try each method out and see which you prefer.
    Do you find the BRS works with other RW's besides ONR ?
  1. Question on rinseless wash
    By rlabar1288 in forum Ask your detailing questions!
    Last Post: 11-12-2018, 04:47 PM
  2. What are you all using? Rinseless wash question.
    Last Post: 10-07-2016, 09:31 PM
  3. Rinseless wash question
    By RecurveTrail214 in forum Auto Detailing 101
    Last Post: 03-19-2016, 05:42 AM
  4. Rinseless wash question
    By SeanChav in forum Auto Detailing 101
    Last Post: 10-13-2015, 02:44 PM
  5. Rinseless wash 2BM question
    By KillaCam in forum Auto Detailing 101
    Last Post: 06-28-2013, 02:09 AM
