Results 1 to 8 of 8
    May 2007
    683
    TW Flex Wax drying aid?
    Any thoughts on what to use? Thought about A certain companies graphene detailer, but interested in the thoughts of others. Thanks!
    Dec 2018
    7,179
    Re: TW Flex Wax drying aid?
    Quote Originally Posted by BTLew81 View Post
    If you wanna stay graphene Adam’s graphene detail spray. If you don’t care (I don’tvthink it matters much) and want to stay with TW, Hybrid Solutions Wet Wax
    Super Member joebruin77's Avatar
    Jan 2019
    258
    TW Flex Wax itself can be used as a drying aid. I would just stick with the Flex Wax.
    Mar 2011
    PA
    5,794
    Quote Originally Posted by joebruin77 View Post
    THIS. Right from the directions...
    The third possible way is the one-step version that is the biggest time saver. Simply apply wet and then dry.
    After you have a good base of it on, use it that way to maintain/refresh the finish as needed.
    2018 Colorado ZR2
    May 2007
    683
    Thanks. I just like to use something while drying. I have the wet wax but wasn’t sure on compatibility. Maybe I’ll try a graphene detail spray.
    Jan 2019
    258
    Since the TW Flex Wax is designed to be used as a drying aid (among the several different ways it is designed to be used), is there a particular reason why you do not want to use the TW Flex Wax as a drying aid? If you are looking for a drying aid that is compatible with Flex Wax, I don't think you can get much more compatible than the Flex Wax itself.
    May 2007
    683
    Really just the cost. I wash often in the summer and weekly washes will get expensive with flex wax as a drying aid. I’ve considered diluting it for a drying aid and maybe using it full strength every couple of months. Off label, I know. ��
    Jan 2019
    258
    Ah, that makes sense. One of my favorite, more cost effective drying aids is Meguiars D156. I haven't tried it on top of Flex Wax, but I would be curious if that would work.
    That said, I would also be curious if you used Flex Wax as a drying aid and only used one spray per panel, how long would a bottle of Flex Wax last?
  1. Replies: 16
    Last Post: 05-12-2018, 09:09 PM
  2. Replies: 40
    Last Post: 09-17-2016, 03:22 AM
  3. Waffle weave drying towels not drying anymore
    By octane in forum Auto Detailing 101
    Last Post: 11-12-2012, 04:26 PM
  4. FLEX XC 3401, FLEX L3403, or FLEX PE14-2-150 for Gel Coat
    By MichaelD in forum Boat & Marine Craft Detailing
    Last Post: 10-16-2012, 01:28 AM
  5. Blow Drying Instead of Hand Drying
    By Tank_McNamara in forum Auto Detailing 101
    Last Post: 05-30-2010, 10:47 PM
