Dark spot in paint after wet and dry
Hi all,
Recently resprayed a car with 2k direct gloss single colour and been flattening it ready for final polish with 2000grit wet and dry. In a number of areas a dark spot (shade or two darker than normal colour) have appeared after sanding, these vary from coin sized to cluster of dimples/pinhole sized. Does anyone know why this has happened and how to fix (preferably without respraying the whole car/panel again)?
Showing above door handle:
Re: Dark spot in paint after wet and dry
When you say "single colour" are you referring to single-stage without clear?
Or did you also apply a clear-coat?
If single stage...
The one larger area looks like you sanded through the top coat of color to the previous coat and the ring you see is that transition from one coat to the next.
The smaller "clusters" look like shiny spots that just haven't been sanded yet. Think of the orange peel as peaks and valleys and you've only hit the peaks so far. The valleys remain as un-sanded shiny spots.
If clear-coated...
Similar to the single stage explanation except the ring you see is where you sanded through the clear and exposed the color base coat.
The smaller "clusters" are the same as the explanation of the single-stage.
In either case there's only one fix... Start over and respray.
Originally Posted by rockov
Hi all,
Since this is your first post,
Welcome to AutogeekOnline!
Here's your picture, I rotated it and uploaded to your free gallery here on AGO
The drizzle looking runs or stains are confusing? Almost looks like some type of liquid stain?
Besides that I go along with what John aka 2black1s posted.
yes single stage no clear, I would agree with you about it looking like its been sanded through. What gets me is the car was primed then 3 coats of single stage was put on, so i am wondering why there is a change in shade between coats?
many different reasons could be the cause. one being full coverage. the underlying coats may not have fully covered the primer. if a grey primer, the coats will get darker on each coat until full coverage.
some paint brands have a lower amount of pigments so more coats for full coverage.
fix= respray
a rule of thumb is that wet/color sanding will remove 1 coat of paint. its always a good idea on single stage to have 4-5 coats.
although the drizzley runs mentions look suspicious. were there runs in the paint there?
enlarging the pic, it looks like theres a darker spot to the side near the tape. take a real close look and see if you can define lines between coats.
The reason for the ring (or as you describe - different shades) is because the metallic in the paint is dispersed separately in each coat, not necessarily throughout the entire multi-coat matrix, and also not necessarily perfectly uniform within an individual coat. As such, when you sand or polish through one coat you will see that ring or change in shade. You can also see color shifts even if you don't go all the way through from coat to coat.
The cause is the numbers of metallic particles, their distance relationship and orientation to the surface in the affected area. The uniformity of the metallic particles within any coat of paint is dependent on many factors... Paint reduction, air pressure at the gun, application technique - heavy/wet or not so heavy/wet, distance from gun to surface, dry time, and so on. As those parameters change, so do the paints reflective qualities, hence the color disparities.
Mike has an article about this in which he calls the phenomenon "Tiger Stripes". While stripes are certainly one way in which this condition presents itself, it may also be any random pattern of blotchiness, mottling, and/or color shifting.
Wet sanding and polishing of single stage metallic colors is as risky as it gets in the refinishing and detailing worlds.
Think of it like this... With a clear-coated finish you typically have 2 or 3 coats of clear to work with before you'd ever expose the base coat. With a single-stage metallic color you only have one coat before you reach the prior coat, and even less before you can start to alter the reflective qualities of the metallic even within the same coat of paint.
And then to compound matters, the final coat of single-stage metallics is often mist-coated to provide for uniform dispersement of the metallic particles at the paint's surface. So now the metallic particles are very close to the surface and any sanding or polishing can disrupt that uniformity in a heartbeat.
The preceding explanation applies to "refinished" metallic colors.
In the old days of single-stage factory paints these issues, while they did exist, were not as prominent. The paint process at the factory resulted in a more even distribution of the metallic throughout the entire paint matrix. Even so, sanding and/or polishing could create similar issues with the factory finish, but not to the same degree as with refinished parts.
If you want a glass smooth finish with a metallic color, you have to clear-coat it. It's simply not possible to sand and polish a single-stage metallic color perfectly smooth without the likelihood of issues like you are experiencing. Single-stage metallics can only be lightly polished, and even that poses some risk.
By Coreykeyz in forum Auto Detailing 101
Last Post: 12-07-2020, 07:31 PM
By briguy in forum Ask your detailing questions!
Last Post: 12-16-2016, 10:22 AM
By john-burgess in forum Auto Detailing 101
Last Post: 08-11-2014, 09:48 PM
By TCB in forum Auto Detailing 101
Last Post: 06-18-2007, 03:34 PM
By Excessive Detail in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-11-2006, 04:37 PM
