Results 1 to 4 of 4
    Oct 2014
    Lightbulb Ceramic coat water spots - removing it with D140 wheel brightener - safe? recommendations? dilution?
    I applied CarPro cQuartz UK 3.0 on my car about 8 months, there are a few stubborn water spots that won't come off with vinegar and water 50/50. I purchased some D140 as I saw a few suggestions online this is a trick used by detailers to quickly and effortlessly remove these stubborn spots.
    A few questions if you can help:
    - Should D140 wheel brightener be diluted for use as a water spot remover? what kind of dilution formula should I use?
    - Is D140 ceramic coat safe or will it affect the top coat of cQuartz?
    - Any tips or recommendations for application I should follow? (e.g: don't let sit on paint longer than X, wash car before and after application)
    Thanks
    Super Member Rsurfer's Avatar
    Jan 2007
    14,098
    Re: Ceramic coat water spots - removing it with D140 wheel brightener - safe? recommendations? dilution?
    I would try Car Pro's Spotless first, as it was made to remove water spots and not remove the 3.0.
    It appears you haven't used WB..do yourself a favor and stay away from that caustic chemical.
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    Wheel Brightener still has a place but I find myself using it less and less over the years. Knowing what I know now, I should have worn a respirator back then when working with it. lol
    I also would suggest trying out CarPro Spotless. Worst case scenario is to use Essence to remove it. Essence has been used to repair fading coatings and I used it to remove a scratch from a vehicle coated with CQUK not too long ago. After the scratch was gone, I went back and buff out that particular panel with Essence and coated it again with CQUK. I am just anal that way since it was not my car.
    Waterspots generally are much easier to deal with when they are fresh. Once baked in, I often find myself resorting to polishing it off.
  4. Likes Rsurfer liked this post
  5. #4
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    •IMO:
    -An AIO, such as Klasse AIO, is a much “safer”
    product to use for water-spot removal from
    CQuartz UK 3.0, than Meguiar’s D140 will
    ever be—regardless its dilution ratio.
    RE: Klasse AIO/“safer”
    •won’t harm the UK 3.0 Coating
    •doesn’t contain any Ammonium Bi-Fluoride
    (ABF)
  1. PPE for Meguiars D140 Wheel Brightener
    By Lakeside Detail in forum Auto Detailing 101
    Last Post: 09-05-2014, 01:56 AM
  2. Meguiars D140 Wheel Brightener Dangers?
    By T0RCH3D in forum Auto Detailing 101
    Last Post: 08-22-2013, 07:48 PM
  3. Megs D140 Wheel brightener
    By flamed03vert in forum Products Guides
    Last Post: 10-14-2012, 10:26 AM
  4. Meguiars D140 Wheel Brightener Question !!!
    By Webb in forum Auto Detailing 101
    Last Post: 05-22-2012, 04:07 PM
  5. Wheel brightener D140 vS. APC+ 4:1 ?
    By cobraa in forum Auto Detailing 101
    Last Post: 09-28-2010, 11:05 AM
