Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Nov 2020
    What are these spots on my car hood?
    What are these spots on my car hood?-car_paint_spot_0-jpg What are these spots on my car hood?-car_paint_spot_1-jpg What are these spots on my car hood?-car_paint_spot_2-jpg
    I found three gray spots on my hood.
    Tried soap, wax, 92% alcohol, and fingernails, and none removes them. Their surface texture feels smooth, but not as slippery as the clear coat.
    Any idea how to remove them?
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    Re: What are these spots on my car hood?
    Questions for you....
    Is your car garaged or sit outdoor prior to this?
    Did you Park in a indoor parking Lot?
    Did you recently drove under an overpass or a bridge under construction or road maintenance?
    How long has it sat on the paint?
  3. Likes Mike Hoekstra liked this post
  4. #3
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    some type of etching- probably going to have to use a polish- try by hand first, but might have to break out the polisher
  5. Likes Coatingsarecrack liked this post
  6. #4
    Dec 2018
    7,171
    Agreed if doesn’t feel raised some thing etched into paint. As stated above i would try hand polishing with different levels of abrasive polishes. StRt with least aggressive you have
  7. Thanks luckydawg thanked for this post
  8. #5
    Aug 2013
    St Louis metro (Illinois)
    5,809
    Agree on the etching. To me they look like a bird dropping(s) that wasn't washed off in time and etched the clear coat.
  9. Likes Mike Hoekstra liked this post
  10. #6
    Super Member Mike Hoekstra's Avatar
    May 2020
    Grand Forks, ND
    470
    Without knowing all of the contributing factors, I am going to say bird droppings and etching from that. Cut or polish them out.
    Owner/Operator Auto Massage LLC - www.automassagellc.com
    Custom painter and commissioned artist - www.spikedairstudio.com
  11. #7
    Jan 2015
    Simi Valley, CA
    1,783
    I'll disagree with all of the "etching" comments... If you look at the close up pics (especially #2) it appears that there is some type of material bonded to the surface. It appears "proud" of the surface, not "recessed" as would be the case with etching.
    Exactly what the material is? I have no idea.
    Some type of careful scraping/abrading action followed by a localized polishing would be my thought on how to remove, but only and after I exhausted some less aggressive attempts like solvent, polish, etc.
  12. #8
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Were you parked under a tree? Tree sap maybe?
  13. #9
    Nov 2020
    Quote Originally Posted by psnt1ol View Post
    The car had been parked outside for an year since it's new, and it has been moved into a garage for 4 month until now.
    I believe the spots are from times when the car was parked outside, and I would say it's about 10 months ago.
    The are less likely from bird drops, since I cleaned bird drops if I see them, and the areas would be larger.
  14. #10
    Dec 2018
    7,171
    Quote Originally Posted by joe6666 View Post
    Do they feel raised as something on the paint, smooth or recessed(in the paint)?
    If raised i would give a plastic razor blade a try. Their available on AG. Use alot of Lube.
  1. Used Car - Spots on hood
    By Quitz in forum Ask your detailing questions!
    Last Post: 06-02-2020, 10:09 AM
  2. Spots in paint on hood, not sure what to do next.
    By drewrob26 in forum Auto Detailing 101
    Last Post: 10-07-2014, 01:50 PM
  3. Spots on my hood..
    By twich31 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 09-20-2014, 11:39 PM
  4. tiny spots on my hood
    By jwollam in forum Auto Detailing 101
    Last Post: 10-30-2013, 10:50 PM
  5. Dry spots on my hood.
    By pirex in forum Auto Detailing 101
    Last Post: 06-06-2007, 11:14 AM
