Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Pad cleaning?
    Regular Member soapboxpreacher's Avatar
    Feb 2014
    Chicago, IL
    106
    Pad cleaning?
    How and what do you use for pad cleaning? And is it worth it or dump the pads when you are done?
    2018 Jeep GC High Altitude
    2018 Tesla Model 3 Performance with Sport Package
    Feb 2014
    Chicago, IL
    106
    Re: Pad cleaning?
    Oh and do you need a dedicated pad cleaning solutions or can something I have around the house to clean these?
    Super Member Hermes1's Avatar
    Sep 2014
    Nomad, wherever we park our rig
    255
    Re: Pad cleaning?
    I like the powder versions that are mixed with water so I can soak the pads as they become loaded, then scrub them with a pad brush when done. The ones I have used are McKee's & Blackfire which have worked well. Also after thoroughly scrubbing and rinsing, I throw them in the washing machine.
    Sincerely, Bruce
    2015 Ram Big Horn CC 3500 Cummins DRW w/AISIN tranny
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Re: Pad cleaning?
    I don’t care for any powdered type cleaner. Problem is that powders don’t always dissolve properly. That can create a problem next time you buff if one of those particles get dislodged from the pad.
    I use an APC with a nylon pad conditioning brush with lots of free flowing water followed by a trip in the washing machine. Finally followed by drying on a rack velcro side up.
    Jim
    Jan 2014
    SoCal
    1,122
    Re: Pad cleaning?
    D-limonene @ 10 percent.
    So, however you buy it, dilute it with distilled water to get a 10 percent solution. I have had great results with Citra-solv (probably 90 percent d-limonene) . But, usually I use Citra-Blast (50 percent d-limonene) because you don't need the quality of a citra-solv type product to clean pads. You do have to shake Citra-Blast prior to use. But, that's really no big deal.
    You can use pad cleaner (or IPA ?) as a final step if you don't trust leaving possible d-limonene residue in your pads.
    Keep in mind, a product like this is probably only needed if a type of sealer is in the pads. Compounds and polishes can be cleaned with a lot cheaper products.
    Apr 2012
    7,494
    Re: Pad cleaning?
    I dump mine in the HE washing machine on a long cycle with steam. I pre-spray with an APC and toss them in. I use 3D Towel Kleen.
    They come out good as new.
    Yeah, the machine smells like car products after but I then run the same cycle with Tide washer cleaner and all is good. Been doing it this way for years.
    2019 Nissan Rogue SL
  7. Likes PaulMys liked this post
  8. #7
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: Pad cleaning?
    I spray mine with McKee's polishing pad cleaner, agitate with a stiff brush, then plop them in a bucket of 3D Towel Kleen solution until I'm all done polishing.
    After that, they come clean in the sink with little effort.
  9. Thanks Hermes1 thanked for this post
    Likes Hermes1 liked this post
  10. #8
    Jan 2020
    109
    Re: Pad cleaning?
    I've had good results with Blackfire's pad cleaner. The smell is harsh but it's the only thing I've found that'll remove HD speed. I spray it on, and let it soak for a few minutes then wash them by hand under hot water.
  11. #9
    Apr 2017
    137
    Re: Pad cleaning?
    Is there a product that works on microfiber towels as well as the foam pads?
    I see custmsprty and PaulMys use the 3D towel clean but it's not the only product. I'm a weekend warrior and trying not to have a bunch of products is why I ask. I was wondering if one could get away with just the 3d towel clean but would need a little extra effort with the pads when using it?
  12. #10
    Super Member nrengle's Avatar
    Oct 2007
    Columbus, Ohio
    618
    Re: Pad cleaning?
    Of note, I tried a way to dry my pads quickly over the weekend. Air fluff in my dryer on the drying rack. Just blows room temp airnover them. 45 minutes later all 6 pads I had in there were dry. Even put them back on the rotary at full speed to see if any water would fly off, nothing.
  1. Replies: 2
    Last Post: 06-01-2020, 07:08 PM
  2. Replies: 17
    Last Post: 04-15-2020, 11:33 AM
  3. Washing and cleaning Compound and Polish Self-Cleaning Caps
    Last Post: 09-04-2019, 03:40 PM
  4. Steam cleaning interiors? Cleaning interiors?
    Last Post: 08-06-2017, 01:49 PM
  5. Cleaning wax/sealant out of foam pads with the Grit Guard Cleaning bucket?
    By TotalNewbie in forum Wool & Foam Buffing Pads
    Last Post: 05-29-2013, 08:43 PM
