Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Super Member TMQ's Avatar
    Mar 2015
    Germantown, Md
    2,243
    Can one ceramic coat single stage paint??
    There’s an old caddy covert with very clean single stage paint. It look good as it is. Probably need a good cleaning and maybe a mild polish.
    Just never occurred to me if one can actually lay down a coating on single stage paint.
    BTW-I have not seen this. Someone was telling about it and was wondering if coating can be done.
    Tom
    Mr Tommy's
    Wash, Buff, Wax
    Website: mrtommyshine.com
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Re: Can one ceramic coat single stage paint??
    I see no reason against such.
    Maybe this past article from Mike P will help answer some of your questions.
    Can you apply a ceramic coating to old school single stage lacquer paint?
  3. Thanks TMQ thanked for this post
  4. #3
    Super Member 98CayenneTA's Avatar
    Aug 2020
    Minnesota
    593
    Yes, I actually do it somewhat often with zero negative effects.
    I, myself, no matter how in depth the correction I always make Carpro Essence my base before coating.
    This 5.0 is going on 2 years and is still beading very well and also not even a hint of oxidizing.
    That Grand National is also performing very well to date. (About 6 months)
    Ripping through your mind like a hurricane full of novocaine
  5. Thanks TMQ, Craig Encinitas thanked for this post
    Likes fly07sti, PaulMys, Craig Encinitas liked this post
  6. #4
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    I totally agree with 98CayanneTA. I always do at least a quick polish with Essence prior to coating with UK3.0. And yes I have coated numerous SS paints with a ceramic coating with no ill effects. I personally like waxing SS paints, but if a customer wants there vehicle coated, it’s getting coated.
  7. Thanks TMQ thanked for this post
  8. #5
    Super Member Sizzle Chest's Avatar
    Apr 2011
    Naples, FL
    5,901
    Tom, you can. I have. You can sometimes run into blotchiness on some SS paint.
    I've only run across this on one vehicle, Ferrari 308 in Rosso Corsa. Don't know if it was that particular paint, color or what, but it had some blotchy marks in certain areas after coating. I re-polished and re-coated and it seemed ok in a variety of lighting.
    I'm still wary about doing it and as stated above, I prefer to wax or seal SS paint.
    Scott Harle
    Autodermatology
    #autodermatology
  9. Thanks TMQ thanked for this post
  10. #6
    Mar 2015
    Germantown, Md
    2,243
    Thanks everyone....
    Will let owner know that it's possible. But will need to see the car and do a test.
    Thanks..
    Tom
    Mr Tommy's
    Wash, Buff, Wax
  11. #7
    Just to comment....
    There's a reaction difference to OLD oxidized single stage paint versus any single stage paint that already has a hard shine.
    There's also 2 different kinds of single stage paint.
    Old school solvent evaporation single stage paint - this would be old school lacquer or enamel
    Modern single stage URETHANE - like Toyota still uses for some of their white vehicles.
    FWIW
    And - Always do a TEST SPOT before trying to
    1. Chemically strip the paint
    2. Install the coating
    Chemically striping some old single stage paint, in other words WIPING THEM WITH A SOLVENT - might tend to make the paint look dull. This is because they tend to me more porous and more susceptible to dulling via chemicals.
  12. #8
    Here's an CUSTOM URETHANE single stage paint
    Detailer’s Paint Coating on Single Stage Paint
  13. #9
    Here's a FACTORY URETHANE single stage paint
    This is also a text book example of taking a great before picture (before you make a shiny spot doing your Test Spot), and then framing up and taking the same location shot for the after shot.
    RUPES EASY GLOSS System - EXTREME MAKEOVER - 2006 Toyota Tundra - YEARS of neglect!
    BEFORE
    AFTER
  14. Thanks TMQ thanked for this post
    Likes Thomkirby liked this post
  15. #10
    Mar 2015
    Germantown, Md
    2,243
    Thanks Mike...
    That is why need to see the paint. Been repainted back in 70's or 80's. Not sure.
    Thinking---Custom Urethane because of repaint.
    Need to make sure it is not the old lacquer or enamel paint!
    Tom
    Mr Tommy's
    Wash, Buff, Wax
  1. Can you apply a ceramic coating to old school single stage lacquer paint?
    Last Post: 06-25-2019, 01:15 PM
  2. Ceramic Coating on single stage paint
    By mtrisnohadi in forum Ask your detailing questions!
    Last Post: 06-01-2019, 08:09 AM
  3. Gtechniq C1/CSL + EXO for single stage paint/no clear coat?
    By seadog176 in forum Auto Detailing 101
    Last Post: 03-02-2017, 08:32 AM
  4. Ceramic Coating a Single Stage Paint.
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 09-28-2016, 07:05 AM
  5. Colored clear coat or single stage paint?
    By Goodloe3 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-14-2011, 11:08 PM
