Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Nov 2009
    Pasadena, CA
    12,615
    Re: My new favorite one step polish!
    Quote Originally Posted by Dr Oldz View Post
    Chances are yes. I find the white hybrid force pads and 3D one can accomplish the amount of correction I’m looking for on a one step polish job. Of course I will try different pads in my test areas.
    Allow me to explain why a white force hybrid pads usually work so well. The abrasives in the polish do most of the cutting. The pad provides “some” cut. Generally speaking a coarser pad has bigger open areas with harder or sharper foam. Problem with coarser pads is there isn’t as much surface area contacting the paint due to bigger pores in the foam. When you have more surface area of the pad with micro abrasives(3d one) between the pad and the paint, you are actually getting more work done over time. So while in 4 section passes a coarser pad will cut faster and perhaps leave its own marring behind. In situations where you are doing 6+ section passes, the white pad will actually out cut the other pad due to the abrasives in the 3D One doing the work and not the pad. It’s one reason a wool pad cuts so well.... along with being an abrasive itself, wool has a lot of surface area to allow the abrasives work between the wool and paint. This goes more so for non diminishing abrasives.
    Again remember this is in a one step application. Key is number of passes. Now a two step, cutting with less passes is a benefit. In a one step, I’m more worried about finish quality with max cutting but under the realization I’m not going to get the paint 100%.
    Does any of that make sense, Mark?
    Hey Jim, thanks for the explanation. It does make sense. I have the 3401, 3D One, and white force pads. I will give this combo a shot. My new favorite one step polish!
    '03 Corvette Z06
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    I've used both, 3D One and Cut & Finish recently. I can't really compare the two. Same kind of pads, same polisher, same paint, same results, to me at least.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
  3. #13
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    What type of vehicle or paint did you work on? Do you think someone working with a non-forced rotation DA polisher would get the same results?
    From hard to soft paint.
    No, you won’t get the same correction In the same amount of time with a long throw as a forced rotation DA because you can apply pressure and get zero pad stalling.
    Jim
  4. #14
    Aug 2010
    NE PA
    4,462
    Quote Originally Posted by WillSports3 View Post
    I use 3D One with Orange HD pads and a 21mm long throw DA. It's a good combo. What I like about it is that I can use it for my usual 4 passes and get great results. I would not say this is a no-dust product though, because temperature will dictate dusting if any. I can also use it with a solid 6 passes and get better results, just depends on what I'm trying to do.
    Try using a bit more polish. Most likely will solve the dusting for you. I typically run a heavy continuous bead of One on the outside edge of the pad and get zero dusting.
    Jim
  5. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  1. Favorite one step polish
    By bigbadbp7 in forum Auto Detailing 101
    Last Post: 04-07-2014, 01:38 PM
  2. Your favorite 1-step pad?
    Last Post: 04-10-2012, 12:47 PM
  3. Most Favorite Step in Detailing
    By ScottB in forum Auto Detailing 101
    Last Post: 12-01-2011, 09:28 AM
  4. What is your favorite One-step polish?
    By cobraa in forum Auto Detailing 101
    Last Post: 11-21-2011, 08:01 PM
  5. Favorite single step polish
    By qship5 in forum Ask your detailing questions!
    Last Post: 11-20-2009, 09:36 PM
