Re: McKee's 360
Originally Posted by
NJNinja
I'll have to take some pictures. My car was polished then 360 applied. The water beading was poor after a week or two. The car looks good, so I'm not sure what exactly that means. Is water beading what you're ultimately looking for? If so, this product has failed miserably. I've been washing and topping with Hydro Blue.
Turtle Wax SNS was far more durable. Night and day.
If you rub the area that only had 360 with your finger (when paint is clean), does it feel slick in any way or does it make a squeaky clean sound easily?
McKee's 360
Eldorado2k
I’d love to see many more tests.. The only requirements are that the AIO be used as a stand-alone, meaning no toppers, no drying aids, no wax & wax soaps, no wipedowns in between bucket washes and the 1st wash should come no sooner than 2 weeks like mine did.
No beading from spray bottles, show us the hose nozzle. No garage queens.
Will do. I applied over what is 5 month old Cancoat with an LC orange pad on DA speed 4. I figure that should easily remove the underneath coat. No gloss enhancers, wipedowns, etc. I’ll avoid washing for 2 weeks but can’t guarantee it won’t get wet before then. When I do wash it will be with Hyper Wash.
Re: McKee's 360
NJNinja
Water beading is definitely a good indicator... However I’ve come to notice that some products lately have really jumped on that bandwagon and have somehow raised the volume in terms of beading while failing to provide any form of real protection in other areas, mainly from bonded contaminants. That’s the main reason I’m not a fan of coatings.
What good is water beading if your paint isn’t completely smooth while you’re wiping your car down?
I haven’t tested any of those new TW products, but yea generally speaking good water beading should be a good indicator, but don’t believe its really protecting unless it can also pass a baggie test throughout.
Re: McKee's 360
I'm hoping to do a wash some time this week and will report back. We're not allowed to have more than one day of sun in a row anymore around here apparently, so it will be dependent on the weather.
Re: McKee's 360
acuRAS82
When did you apply that? McKee’s 360?
What was the Cancoats water behavior like at the 5 month mark?
Re: McKee's 360
Eldorado2k
In your area it may be easy to check products versus stuck on contamination, but where I live I barely need to iron-x or clay once a year (but I do so to be thorough). In the northeast my main indicator of protection is resistance to etching from water droplets and bugs/bird poo... even though the latter may be impossible if you leave it for too long.
Belo liked this post
Re: McKee's 360
Eldorado2k
I applied 15 mins ago. CanCoat behavior is still excellent. If you question the bareness of my surface I can prep polish it, make sure it’s bare and reapply 360.
Re: McKee's 360
acuRAS82
Did you polish just the roof?
Re: McKee's 360
Eldorado2k
Yes, just the driver’s side front roof. The rest remains CanCoat
Re: McKee's 360
Do the hood, that way you have a proper sized test panel to show the water behavior. And due to the longevity of Cancoat I think a paint prep polish should take place, along with a quik water test afterwards to make sure the paint is bare.
