Page 2 of 17 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 165
Thread: McKee's 360
    Nov 2016
    253
    Re: McKee's 360
    I just tried it on a vehicle for the first time two weeks ago, bought it because of it's reputation for durability. We'll see how it goes. I was hoping to let it ride for a couple of months then follow up with hi-def. Really trying to keep things simple this year.
  2. Likes acuRAS82 liked this post
  3. #12
    May 2017
    Pittsburgh PA
    2,847
    Re: McKee's 360
    Quote Originally Posted by DetailZeus View Post
    Not sure where you are, but it should last a couple months easily unless you’re in extreme climate like Arizona/Nevada (maybe would still last, but no knowledge from me).
  4. #13
    Apr 2012
    7,494
    Re: McKee's 360
    Or the "Sunshine State"
    2019 Nissan Rogue SL
  5. #14
    May 2017
    Pittsburgh PA
    2,847
    Re: McKee's 360
    Quote Originally Posted by custmsprty View Post
    I wasn’t sure if the humid heat was as rough on LSPs, since Nick always talked about this stuff lasting 8+ months on a car there. Figured maybe the moisture in the air absorbs some sun rays...?
  6. #15
    Nov 2015
    Los Angeles, California
    13,765
    Re: McKee's 360
    Ok the test has officially started: McKee’s 37 360 AIO longevity test.
    *Perfectly Prepped Surface. No corners were cut*
    I started by bucket washing the entire vehicle with Megs Hyper Wash.
    I substituted the claybar with a Med. Grade Nanoskin Mitt to remove any bonded contaminants.
    Next step: McKee’s 37 Coating Prep Polish.
    Most might consider this overkill after using a claymitt right? Take a look at this... This was a brand new applicator. I polished by Hand... And this was only Half of the roof!
    Here’s the other side of the brand new applicator.
    Now the roof has been fully decontaminated and prepped as good as possible.
    Side A:
    Side B:
    Tape down the middle: Excuse my sloppy tape job here.. I didn’t want to waste my good Carpro tape, so I just used regular masking tape.
    Drivers side gets McKee’s 37 360 AIO. Applied w/G21 on a 7” LC HD Orbital Foam Finishing Pad. Speed 4.5
    I broke the drivers side of the roof into 3 sections for the application.
    2nd section:
    3rd and final section:
    Next I applied liquid sealant onto the Passenger side while while allowing the 360 AIO a few minutes to haze up.
    This is what it looked like once everything was all done. Notice the control section down the middle where the tape was laid down.
    My plan is to come back in 2 weeks and test the water behavior + give it a wash. I don’t expect it to rain, nor do I really expect this vehicle to do much if any moving because of the whole quarantine...
    Longevity test has officially started.McKee's 360
  7. Thanks acuRAS82, CleanIT, VitreousHumor thanked for this post
  8. #16
    May 2017
    Pittsburgh PA
    2,847
    Re: McKee's 360
    Thanks! I’ve been using prep polishes and there’s no doubt they pick up a ton of embedded contaminants that clay can’t touch.
    I look forward to this test. I assume the mystery sealant is your regular LSP sealant?
  9. Likes Eldorado2k liked this post
  10. #17
    Super Member ScottH's Avatar
    Nov 2015
    Northern NJ
    895
    Re: McKee's 360
    Nice to see this test Eldorado2K.
    ScottH
  11. Thanks Eldorado2k thanked for this post
  12. #18
    Nov 2015
    13,765
    Re: McKee's 360
    I know it’s straight up shocking.. I would imagine for some seeing it in person might be 1 of those moments that could have you re thinking your whole process. If you’re OCD this could definitely be an opening of a can of worms. Lol.
    And yes.
  13. #19
    Super Member Belo's Avatar
    Jul 2014
    Rochester, NY
    492
    Re: McKee's 360
    And yes.
    it's also upsetting in the fact that detailing a car is already some pretty time intensive back breaking work, especially if you plan to work on glass, tires, rims and trim. To think there's another step I could add.... oh man.
    2009 Pontiac G8GT
    2015 Ford Explorer Limited
    2019 Chevy Silverado RST Z71
  14. #20
    Nov 2015
    13,765
    Re: McKee's 360
    Quote Originally Posted by Belo View Post
    A customer’s about to drop off a Tahoe for me to detail in 30min... Reading your post just squeezed a bit of energy off my power bar. [imagine a video game] lol.
  1. McKee's 37 Paint Coating, or Mckee's 37 Hi Def Paint Sealant?
    By mk9750 in forum Hot topics & Frequently Asked Questions
    Last Post: 08-30-2018, 08:33 PM
  2. Mckee's Pad Rejuvanator/Mckee's Pad Cleaner
    Last Post: 07-27-2017, 07:58 AM
  3. Replies: 12
    Last Post: 07-08-2017, 08:50 AM
  4. Replies: 2
    Last Post: 10-09-2016, 11:47 AM
