Microfiber cutting pads
When using the microfiber cutting pads, you prime, then add working product, and to keep residue down after each section clean the pad. Do I need to reprime the pad, add working product and work it, or once I prime it, it’s primed until I change to a fresh pad. I’ve seen and researched a lot but this isn’t really talked about. Thanks
Re: Microfiber cutting pads
Once the pad is thoroughly primed and abrasive liquid has covered every fiber of the surface you will not need to re-prime the pad after each time you clean out the pad. We typically blow them out with a Tornador and then add a few drops of product before working on the next section.
