Results 1 to 4 of 4
    Junior Member georgez's Avatar
    Jan 2012
    Bellevue, WA
    56
    Removing double stick tape foam
    Had a mount stuck on my dashboard which i removed. It was held down with double stick tape that had a middle foam layer. The car is a BMW 3 series E90 and I think the dash is made of a softer vinyl plastic material. Pictures attached. I've removed as much as i could but was wondering if anyone had any pointers on how to remove the remaining residue.
    Removing double stick tape foam-img_5938-jpgRemoving double stick tape foam-img_5939-jpg
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Re: Removing double stick tape foam
    Tricky situation.
    Any chemical adhesive remover would probably, or certainly attack/discolor the vinyl.
    I'm far from an expert on this, but the first thing that comes to mind is heat in the form of steam.
  3. Likes custmsprty liked this post
  4. #3
    Regular Member Sleper's Avatar
    Mar 2006
    120
    Try using a blow dryer or a heat gun(be careful very hot and will melt dash) . use a plastic scraper and then an old rag you can throw away. Once done use some adhesive remover or WD40 and you should be gold. Good luck
  5. #4
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Except for a heat source (I’ll suggest
    using a hair dryer) the below kit will
    probably have everything you need to
    take care of this task.
    Afterwards:
    Make sure to apply an interior protectant
    to the entire dashboard. Meguiar’s QID;
    or, perhaps even one of Sonax’s interior
    products, should suffice.
    Please:
    •Do a “Test Spot”.
    •Take your time (this isn’t a rush job).
  1. Automotive tape won't stick!
    Last Post: 05-22-2015, 08:53 AM
  2. removing aggressive double sided tape from plastic spoiler
    By builthatch in forum Auto Detailing 101
    Last Post: 04-11-2013, 12:22 AM
  3. 3M Double Sided Tape Removal
    By AutowerxDetailing in forum Auto Detailing 101
    Last Post: 06-07-2012, 07:50 AM
  4. Will 3M double sided tape ruin paint?
    By itzJoker in forum Auto Detailing 101
    Last Post: 06-13-2010, 06:42 AM
  5. Does AG currently carry the 7/8" x 15' 3M Double Sided Tape?
    By the_invisible in forum New Car Care Products
    Last Post: 11-09-2009, 08:23 PM
