Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Jul 2016
    3,328
    Re: Paint polish options that are safe on ceramic coating
    I've always wondered what the traditional non abrasive polishes would do to a coating. They wouldn't take it off obviously but would they make it look better temporarily? Idk
    Jul 2016
    3,328
    Quote Originally Posted by carcarecoaches View Post
    If it's a good quality ceramic coating then you might have to wet sand it to remove. We recently had a wet sanding training session and needed to use that technique to remove Gtechniq Crystal Serum Ultra from the painted surface.
    Come on really? How do you know if it's gone or not?
  3. #13
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Well CSU is a professional/authorized intaller only coating so many of here won't have to worry about it. It has been known that it needs to be wet sanded off which is why it is not sold to the unauthorized installer. But most coatings available to the general public can be removed with a polish. That does not take away from it being a quality product.
  4. Likes BudgetPlan1 liked this post
  5. #14
    Super Member Rsurfer's Avatar
    Jan 2007
    14,098
    Wet sanding to remove it imo doesn't make it a better coating.
  6. #15
    Jan 2011
    908
    Exactly. Why would anyone want to go through that hassle anyways?
  7. #16
    Jan 2007
    14,098
    Quote Originally Posted by Kaban View Post
    Exactly and risk burn through.
  8. Likes Kaban liked this post
  9. #17
    Sep 2017
    Sweden
    3,022
    Quote Originally Posted by fightnews View Post
    It's shows almost like when you go through the clearcoat but less visible than that.
    Then how easy a consumer coating is to polishing off depends on how long after the application was done. You have a window from application to a couple of days up to a week when it's usually pretty simple to polishing it off. After a week or so when the coating is fully cured. You might need to be stepping up to a compound. And with some pro coatings even wet sanding but it's not so much of a low grit needed. It can depends on how it shows when you are through the coating on which you go with.
    To polishing a coating I would stay away from as you polishing off the hydrophobic top layer of the coating very easy. So something needs to be replacing this layer. Hence the Carpro Essence Plus and IGL Renew F4 is the choice to go with. Or if you accept that you need to be applying a top coating like of product to get the high performance that you had before. Then some non abrasive polishes/paint cleaners on a very soft finishing pad can do the trick. But to be honest if you have marring and scratches that like Carpro Reload is not able to be filling. I think that you are already through the ceramic coating and to fix it would be polishing it off and reapply it to the whole panel. You could try something like Reload and apply a new coat of it every week. So it's builds up the filling as much as possible. And see if that's enough for you. But any polishing will degrade the ceramic coating even if it's Essence Plus. Have seen some use a more aggressive pad than the recommended Carpro Glosspads. And it did more correction but also degraded the longevity of the coating.
  10. #18
    Super Member JKDesign's Avatar
    Oct 2016
    Portland, ME
    316
    If you run into that scenario again- try MEK (MethylEthylKeytone) it will reverse the chemical binders/bond of the coating and allow you to wipe it off. We ran into this years ago at the collision shop I was working as a painter/prepper at back when coatings first started coming out- the coating would chew up our sandpaper! The MEK saved the day!
  1. Best polish to use before ceramic coating?
    By RMarkJr in forum Auto Detailing 101
    Last Post: 10-12-2020, 11:17 AM
  2. Replies: 5
    Last Post: 07-13-2020, 01:54 PM
  3. Motorcycle paint correction/coating options
    By Radster1986 in forum Auto Detailing 101
    Last Post: 05-04-2018, 11:00 AM
  4. Using a polish on ceramic coating?
    By HAMBO in forum Auto Detailing 101
    Last Post: 06-21-2017, 08:31 PM
  5. Is there a safe way to spot polish a ceramic coating with light scratches?
    By PouncingPanzer in forum Tricks, Tips and Techniques
    Last Post: 06-17-2017, 07:41 AM
