Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Re: Something for plastic cowl on trucks?
    Agreed about using a Detailing Brush or a wide Artist's Brush for Cowls like this. Both for cleaning, and for applying a protectant.
    My general theme if you're not going so far to remove the entire Cowl for such processes would be to use a dampened brush with a diluted mild cleaner to first clean all those nooks and crannies. Think of trying to "pull' the nasties out, wiping the brush continually as you go with a towel. Unless you don't really care about dirts going down under the Cowl and would probably flush with clean water after anyway?
    Then if say using something like Wolfgang WETS, I'd pour a small amount into a small vessel, just lightly dampen the Brush then apply to the Cowl without letting any excess drip under the Cowl. I might start with treating the un-louvered areas first, to diminish the WETS so that you're not over-applying into those holes-louvered areas.
    Hope this idea makes sense and helps.
  2. #22
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by MrOneEyedBoh View Post
    Optimum car wax I didn't think
    was a sealant for plastic trim.
    •That’s what’s nice about many
    of today’s Sealants:
    -they’re multi-purpose: Won’t cause
    any harm, or stain, trim/moldings.
    •Meguiar’s Ultimate Quik Wax is another
    Sealant I use on porous textured black
    plastic components.
    I was hoping to use something dedicated
    that isn't water based.
    I have PERL but it washes off too fast,
    being water based
    The alternative would be some kind of
    dedicated petroleum-based dressing.
    Sorry...
    but I won’t be the one that recommends
    any of those type of dressings to use on your
    cowl project...I refuse to even use them myself!
  3. #23
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    I like the Blackfire Tire & Trim Sealant on plastic wiper cowls. Works great!
    BLACKFIRE Tire & Trim Sealant, plastic trim restorer, tire coating, long lasting tire shine
  4. #24
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by Bobby B. View Post
    Is it water, or petroleum, based?
  5. #25
    Sep 2009
    2,355
    From the Autogeek website -
    BLACKFIRE Tire & Trim Sealant is far more than a trim dressing. This polymer-based trim restorer forms a bond at the molecular level, restoring the surface while coating it in a durable, protective shell. BLACKFIRE Tire & Trim Sealant doesn’t wash off in the rain – it actually causes water to bead up like a wax! Treated surfaces will have a factory-fresh appearance – not a sticky, greasy mess like other so-called trim restorers.
  6. #26
    Dec 2010
    Ohio, USA
    21,057
    So the answer is Yes?
  7. #27
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Yes it's water based or yes it's solvent based??
  8. #28
    Super Member MrOneEyedBoh's Avatar
    Mar 2013
    1,186
    Could I use brilliant shine detailer on it? I have that now .. juts trying to find something I can use readily and or get it locally
  9. #29
    Dec 2010
    Ohio, USA
    21,057
    ...Please interpret:
    TIA.
  10. #30
    Dec 2010
    Ohio, USA
    21,057
    get it locally
    IMO:
    Sonax BSD will work famously; it’ll definitely hold
    you over until you get some Optimum Car Wax.
  1. Windshield cowl to the max.
    By Eldorado2k in forum Show N' Shine
    Last Post: 01-27-2019, 10:51 PM
  2. Chrome plated (plastic) wheels on Ram trucks.
    By PaulMys in forum Auto Detailing 101
    Last Post: 05-10-2016, 01:13 PM
  3. Dulled my cowl
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 04-28-2015, 09:43 AM
  4. cleaning those black plastic grills on trucks
    By 4pbears in forum Auto Detailing 101
    Last Post: 06-29-2007, 06:53 AM
  5. cleaning those black plastic grills on trucks
    Last Post: 06-28-2007, 08:19 PM
