Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 74
  1. #61
    Regular Member HAMBO's Avatar
    Jan 2017
    Los Angeles, CA
    126
    Re: Thinking of getting a black car, that crazy?
    Quote Originally Posted by Kaban View Post
    Get a jet black and do a full vehicle PPF wrap on it. Self healing film will help keep it pretty much 100% swirl free, especially if you hand wash it. Best of both worlds.
    Thanks for the suggestion. I know PPF prevents any damage to the clear coat, but does really avoid swirls (presumably in the PPF itself), and is it resistant at all to dust / pollen or easier to clean? Wouldn’t you just get the same swirls, dust, pollen in the PPF and it would still look the same as a regular black car but safe underneath?
    Thanks
  2. #62
    Jan 2011
    908
    Quote Originally Posted by HAMBO View Post
    Thanks
    PPF absolutely does NOT swirl up anywhere near as much as paint. Suntek, 3M, Stek, and XPEL are all self healing. XPEL would be my last option as their current product is alot more dull looking than it used to be and their self-healing top layer is inferior to the other mentioned brands. We've done many full vehicle wraps simply because it's more cost effective than doing a correction/ceramic coating every few years on a jet black car, plus the film offers chip and scratch resistance and it's the only way to truly preserve paint (correcting a car every few years means you're removing paint every few years, with film you lock in that original paint layer and also eliminate the possibility of sun fade/clear coat failure down the line). If you do manage to get some swirls in the film, you can easily remove them with a heat gun or by simply leaving it out in the sun on a hot day. The material is far more resistant to scratching than even the hardest of paints (Ceramiclear ie.) Full wrap costs around $4,000-$10,000 depending where you live. If you're in Los Angeles, you're in the most expensive market for PPF so it might be worth to ship the car out to another shop that charges less. Everything in California costs double pretty much.
    We used to be 75/25 detailing/PPF but now the market has shifted drastically to where we actually do more PPF work than correction/ceramic as we did in the past decade.
    Edit: yes the film will still get dusty/pollen on top, etc. just like paint, but the difference is, I can grab a MF towel and just go at it on a wrapped car without any concern of causing swirls. Without film, I would not even think about "dusting" a corrected jet black car, just too much risk. You have to treat jet black like you're walking on egg shells. PPF is a complete game changer.
  3. #63
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,376
    I removed some garage dust from my black car with a MF the other day but I do so very gingerly. So far, no marring. I wouldn’t attempt to remove outdoor dust though.
  4. #64
    Jan 2011
    908
    Quote Originally Posted by Bill D View Post
    Yup, you just have to use common sense with black. For example if we correct and coat a jet black car at the shop and it ends up sitting for a few days (usually if a customer is out of town and can't pick up or the weather is bad), we end up blow dusting it with the 8hp Metrovac first and doing a very gentle wipedown with some ONR and a microfiber towel if absolutely necessary. Even then, you might cause a small swirl mark here and there, it's a losing battle. You can only minimize swirls, can't avoid them.
  5. #65
    Feb 2012
    Palatine Illinois, USA
    24,564
    Without going back and re-reading all the posts, has anyone brought up the point about coatings and the little amount of dust they seem to attract? This said, I'd have to have a good paint coating applied to the car the OP is talking about gettingThinking of getting a black car, that crazy?Thinking of getting a black car, that crazy?Thinking of getting a black car, that crazy?
    2022 Elantra N Cyber Gray
  6. #66
    Jan 2011
    908
    Coatings definitely help alot with a black car.
  7. #67
    Feb 2012
    24,564
    In the 5 years of ownership of my old 2013 it was always coated, first with Duragloss coating and 2x's TAC systems power plus and although metallic I felt it always looked good outside where it would sit 9-12 hrs at a time at work. Yes it was garage kept but daily driven year round, so even coated you've just gotta make that commitment and with a coating, you can basically get thr best of both worlds.
    I'd also like to add with a quality WW like N914 or Griot's Garage Brillant Shine RW/Ech2o/etc using the GD method, you could easily wash the car every other day if it made you feel "vetter"Thinking of getting a black car, that crazy?
  8. #68
    Apr 2019
    Houston, Texas
    947
    Black cars look amazing when they’re clean, this is three coats of Pinnacle Liquid Souveran Wax I applied over the last two days!
    How long will it look like this? Probably until Wednesday or Thursday, check that, Monday night as it’s supposed to storm Monday afternoon/evening!
  9. Likes Klasse Act liked this post
  10. #69
    Mar 2006
    2,376
    Yep, they’ll look good for a longer time only if they are garage kept and only driven briefly on sunny days. Not practical for daily driving.
  11. #70
    Jan 2017
    Los Angeles, CA
    126
    Thanks for the feedback.
    Based on all the above I think I’m gonna go with grey (one of my favorite colors). Not prepared to spend PPF $ on something I’m planning to lease, but was a good suggestion. Based on people’s feedback, and I took a stroll through a parking lot to look at the black cars even in this weather and they all showed so much dirt / swirls, just seems like having black for my situation would be too much of a hassle. Thanks for the tips!
  1. 2017 Audi RS7 in Mythos Black Metallic. Gloss crazy!!!
    By Justin at Final Inspection in forum Show N' Shine
    Last Post: 12-04-2017, 02:01 PM
  2. Thinking about Dry Me Crazy
    By conman1395 in forum Auto Detailing 101
    Last Post: 01-20-2015, 07:54 PM
  3. thinking about buying a tornador black
    By thrawn5499 in forum Auto Detailing 101
    Last Post: 04-17-2012, 12:03 PM
  4. Replies: 16
    Last Post: 03-20-2012, 10:16 PM
  5. Thinking Of Buying A Gal. Of Pinnicle Shampoo??am I Crazy
    By trhland in forum Auto Detailing 101
    Last Post: 08-06-2009, 10:06 PM
