How to remove BF Tire and Trim Sealant from Tires
I'm about to start applying Optimum Tire Coating this weekend and I assume that I need to remove/strip the BF Tire and Trim Sealant for the coating to adhere to the tire. The last time I applied the sealant was a couple of weeks ago and I've started trying to clean the sealant off but I'm not sure if it's removed or if I'm making any progress. When I wipe the tires with a mf cloth, very little dirt comes off and the cloth is moderately clean.
How will I know when it's alright to apply the coating?
Thank you
Jay
Re: How to remove BF Tire and Trim Sealant from Tires
Thank you
Jay
Tire should look dull black with no beading or browning.
Currently, they are not that(!) but they're not shiny either. Looks like I've got a lot of work ahead of me this weekend. Thank you for the input.
Sent from my iPad using Autogeekonline mobile app
Use one of those stiff bristled tire brushes (or the attachment for DA or drill) and get some tire cleaner. Speed Master has a decent hand one. The PBMG ones will foam only white (no brown) when the tire is totally clean. If you don’t have any of these, an APC on strong 1:4 dilution could also work but I guess it’s harsher on tires. They still clean well.
I’m not sure how picky the tire coating is but keep scrubbing until you only see soap.... zero brown/dirt. Scrub, rinse, scrub again, etc. It took me about 20-30mibs per tire ping this process to remove a years worth of weekly tire gel, but that time included rinsing and breaks. Not fun work but not too awful and the coating afterwards (mine was Mckees) makes it all worth it.
Originally Posted by acuRAS82
It took me about 20-30mibs per tire ping .
I didn't know you spoke Klingon!
Only with an iPhone as my secret decoder.
Thank you very much! I've washed the tires a couple of times since application and I do not have any browning coming from the tires but I would assume that's from the sealant sealing the tire itself? I did clean them pretty well prior to the sealant but it sounds like a lot of work this weekend!
The proper Klingon translation for 30 minutes is 30 tup, you need to re-calibrate your iphone translator otherwise Capt. Kirk and the Federation will find your ship and destroy you, your crew, and your ship!
Yeah you may still be scrubbing the sealant if you don’t feel much friction and if the water and soap is sort of beading/sheeting away as you scrub. In other words, it won’t quite feel like your brush is contacting the rubber itself. Try working on a small area to see if you keep scrubbing, will the friction with the brush change? Then you know it was sealant still.
If the sealant is still there tight now, chances are it’s worked very well and there isn’t much dirt underneath, so stay positive.
Super Moderator
The Blackfire Tire & Trim Sealant is designed to penetrate deep inside the rubber for months of durable protection. I would use a low profile tire brush with the Pinnacle Black Label Gel Tire Cleaner multiple times to make sure the Blackfire Trim & Tire Sealant has been stripped properly.
Pinnacle Black Label Gel Tire Cleaner - 8 oz.
Low Profile Tire Brush
Spock: "By the Book, Captain, we will remove the Klingon tire gel in 3 days...By the Book"
Kirk: "Sulu, it's been 3 hours, let's go back and check if the tire gel is removed"
Bones: "But you said it would take 3 days Jim!!!"
Spock: "Doctor, I think you should familiarize yourself with the "by the book" code phrase".
Sorry...couldn't resist...
By 58LesPaul in forum Auto Detailing 101
Last Post: 01-07-2017, 08:42 PM
By rmm518 in forum Auto Detailing 101
Last Post: 09-18-2015, 12:05 PM
By 01GreyStangGT in forum New Car Care Products
Last Post: 07-22-2015, 07:04 AM
By Goin Rogue in forum Product Reviews
Last Post: 08-21-2014, 06:41 AM
By Flannigan in forum Product Reviews
Last Post: 07-13-2011, 06:38 AM
