Re: Caked on brake dust removal
You need an acidic wheel cleaner like Meg's Wheel Brightner.
Thanks, I'll give it a shot and post back some pics if it works.
Any of the good wheel cleaners should help. I have always found that the brush you use makes all the difference. I love my Speedmaster wheel brushes. They give the perfect amount of abrasion to remove most of the brake dust without scratching the rims.
Meguiar's Hot Rims Chrome Cleaner is on the acidic side. It is safe on the wheels as long as they are clear coated. It will require some agitation.
I have some chemical guys wheel cleaner and it was like rubbing water on it, even using a decent brush.
I agree with useing an acidic based wheel cleaner. May take a couple of rounds with it. Use a leafblower or a car blowdryer or dry the wheels between the applications of the acid wheel cleaner. To get it so it's not diluted with the water on the wheels after the rinses. You can also try with an iron remover if you have at home. I useally switch between an acidic based wheel cleaner and a dedicated strong iron remover. Just rinse off thoroughly and dry it between the application either product so you don't mix them. If possible take off the a wheel or 2 and you reach the back of the spokes and the barrels easier when cleaning them up.
/ Tony
Wow, the acidic wheel cleaner worked along with some elbow grease and good brushes. Everyone on here was absolutely correct. I ended up using Hot Rims since it was available otc. I'll post pics of the results later. Thanks everyone, they look 100x better.
Post Thanks / Like - 2 Thanks, 1 Likes, 0 Dislikes
