Results 1 to 6 of 6
    Feb 2015
    Ft. Lauderdale,Fl
    615
    Will tire cleaner / coating prep remove wheel coating
    I would like to apply a tire coating. I have a wheel coating on my wheels and am concerned it will remove the coating if any of the prep cleaner drips on the wheels. Should I be concerned?
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Will tire cleaner / coating prep remove wheel coating
    Quote Originally Posted by Whitewater25 View Post
    What wheel coating?
    I doubt it - if it's a quality coating.
    I wouldn't be to concerned BUT I would still be careful.
    What are you using for a tire cleaner and tire coating?
    Super Member spazzz's Avatar
    Jan 2014
    Madison
    1,013
    I had the same question and paranoia because of black wheels.
    I used in one sitting Meguiars D143 at 1/1, Zep 505 at 1/1, 303 tire/rubber cleaner straight and the TW tire cleaner that came in the old Endura coating kit.
    This was done on low profile tires with black wheels coated with UK3.0.
    I sprayed lightly, close to the tire and immediately started to spread it around the 360 of the tire with my wheel brush. I continued with the scrubbing then pressure washed clean between each product.
    I don't have any staining or reduced coating behavior.
    Feb 2015
    Ft. Lauderdale,Fl
    615
    The cleaner is Tuff Shine as is the coating. The wheel coating is 22ple VM1 applied in December.
    Jan 2007
    14,097
    The cleaner is Tuff Shine as is the coating.Great choice The wheel coating is 22ple VM1 applied in DecemberNever used it, but they do make a good paint coating.
  1. Prep for wheel coating and leather coating...?
    Last Post: 06-02-2019, 06:42 PM
  2. Replies: 6
    Last Post: 08-21-2017, 09:27 AM
  3. McKee's Wheel Coating - Prep?
    Last Post: 09-05-2016, 05:50 PM
  4. HELP: How to remove Tire Coating
    By TuxedoTaurus in forum Auto Detailing 101
    Last Post: 08-03-2014, 09:32 PM
