Re: Diving in! Shopping list critique.
You are going to get a lot of recommendations on products to use.
I made a similar post on another thread similar to this.
Compounds: Sonax Cut Max (diminishing abrasive), Meguiar's M110 (non-diminishing abrasive aka SMAT), 3D ACA
Polishes: Sonax Perfect Finish, Sonax EX 04-06, Optimum Hyper Polish, Meguiar's 210 (if you choose to stay with the Megs twins)
Compounding polishes: 3D One, Sonax Cut & Finish
I list a compound because you never know if you need one until you do a test spot.
If you are going with CQUK the Essence pairs nicely with it. It is not required to use the coating. It is a primer polish. I would also add to get yourself some Gliss and use that instead of Reload that comes in the kit.
How is the defects on the paint of the Volvo XC 60?
If you have a lot of swirls I would grab a compound and some mf cutting pads or even some wool pads for a DA polisher. Or you might notice that you will be compounding 2 times with a less aggressive combo. Since they can have pretty hard paints Volvos.
Sonax Cutmax or 3D ACA for compounds
Sonax Cut & Finish or 3D One medium cut polish
Sonax Perfect Finish or EX 04-06 or/and Carpro Essence
Sonax Perfect Finish and Carpro Essence can be usefull if you have a finicky paint on the Subaru or sticky paint as it can be called sometimes.
LC Low Lint Wool Pads or LC Purple Foamed Wool Pads or B&S Uro-Wool is suited for DA polishers. Especially with a 8mm free spinning DA polisher you can be needed to be useing a more aggressive compound and pad combo on harder paints. You might also be considering the Griots Garage 6" polisher with a 5" backing plate on it and 5" or 5.5" pads. It's a notch more powerfull electric motor in it than the PC XP polisher.
By kjk66ss in forum Auto Detailing 101
Last Post: 04-04-2013, 04:45 PM
By amoore311 in forum Auto Detailing 101
Last Post: 03-05-2013, 04:57 PM
By JSchleim18 in forum Auto Detailing 101
Last Post: 04-13-2012, 05:41 PM
By naza in forum Auto Detailing 101
Last Post: 03-26-2011, 07:56 PM
By k20z3kid in forum Off-Topic
Last Post: 03-22-2007, 07:37 PM
