Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
    Apr 2012
    7,494
    Re: Most Cut / Best Finish
    Here's some full size pictures.
    In the last picture you can see my white Nissan Rogue reflection in the back quarter panel of the Porsche
    Link:
    Menzerna Heavy Cut Compound, Fast Gloss 400, FG400 compound
    2019 Nissan Rogue SL
  2. Likes PaulMys liked this post
  3. #12
    Super Member mwoolfso's Avatar
    Jul 2011
    Long Island, NY
    2,592
    Just based on what I read, Mike's recommendation makes a lot of sense. You wouldn't have a lot of resistance from Nissan paint to correct it. If you did want a pure polish, I would recommend Menzerna SF-3500. It will simply, work.
  4. #13
    Jun 2019
    50
    Thanks again all. Sorry. Had to get a couple hours of shut eye ya'll know. Haha
    Man, more products recommended for me to research.
    I'd say the paint on my truck isn't in horrible shape. It's dull and kind of hazy looking. I can see light swirling ( cob webbing maybe ?) and what looks like light water spots down under the surface. They aren't effected by washing or using a spray wax.
    I can't afford to get too carried away with products. Too many other things requiring money. But, I am wanting to get a collection of supplies to take care of the family vehicles.
  5. #14
    Jun 2017
    Islamabad, PK
    38
    I once did one step correction for a friend using Sonax EX 04-06 on Honda paint and the results looked like two step correction. I would choose Sonax polishes over AIO you mentioned.
  6. #15
    Aug 2013
    St Louis metro (Illinois)
    5,860
    How hard is the paint on your Nissan? If it is like many Japanese vehicles, it will be pretty soft and you won't need a heavy compound. A good finishing polish should do the trick.
    My wife's Toyota Highlander has pretty soft paint and I was able to do a one-step polish of that vehicle with great success using Sonax 04-06, Meguiars Ultimate Polish, or Optimum Hyperpolish. In each instance I used Lake Country white Flat and Thin Pro pads. As far as AIO/Cleaner Waxes, I've also used Griots One-Step Sealant and it looked great.
  7. #16
    Apr 2019
    Houston, Texas
    947
    You've comprised a great list of products and it's hard to go wrong with any of them!!
    I've used Blackfire One Step a few times and absolutely love it and I'm a self admitted cheerleader for BF One Step, and it's pretty "bubba proof" without sacrificing quality. I used it on my Black Acura with super soft paint, wifes White X3 with med-hard paint, Black Mercedes C250 with med-hard, and should've used it on a Black Audi S4 (used pinnacle compound and polish instead)...
    The pads i've used to get the best cutting are the LC Orange Pads, I've tried the Whites each time as part of my test spot but the Orange pad did the trick! My goal on each car was to try to get 75%+ of the swirls out of the paint, which One Step accomplished except for the BMW X3. The X3 had a handful of deeper scratches that I couldn't clean up at the time since my skill level isnt quite there for MF Pads...I'll probably tackle it with Pinnacle Compound and Polish later in the year when it cools down. On softer paints...BF One Step all the way!!
    Good Luck
    Jay
  8. #17
    Jun 2019
    50
    Thanks again everybody.
    Keep the ideas and thoughts coming please.
    I've never done this before and still don't have everything I'm going to need to do it. Just trying to get my shopping cart in order.
    I have no idea about the paint hardness on the Nissan truck. Anybody have any experience with them ?
  9. #18
    Aug 2013
    5,860
    Quote Originally Posted by Jayfro View Post
    This is a good example of the trade-offs you can make. In this case, a more agressive orange pad with a milder polish gets you about the similar results as a less agressive pad with a more agressive polish when used on harder paints.
    On my black metallic VW and now my black metallic BMW I'll use a milder compound like the Blackfire Compound and a white pad. I tried using a polish with an orange pad on my black VW and I actually found it to work a little slower on that paint and required more passes for the same level of results. Overall finish in the end was the same. Results could be different on other paints.
  10. #19
    Apr 2019
    Houston, Texas
    947
    So true, that's why the test spot is SO important!
    Jay
  11. #20
    Apr 2019
    Houston, Texas
    947
    Quote Originally Posted by Serenitynow View Post
    Make sure you have enough Pads....I average one pad per panel, around 8-9 but some will use around 6 depending on the vehicle and correction. If you do a Compound and separate Polish, double the amount. Make sure to get a good cutting pad (orange) and a good finishing pad (white)....it adds up quickly!
    Two other things....take your time once you start and have fun!!!
    Jay
  12. Likes PaulMys liked this post
  1. Sonax CutMax vs Cut & Finish? Perfect Finish vs EX 04-06?
    By mwoywod in forum Auto Detailing 101
    Last Post: 07-09-2017, 06:17 AM
  2. Replies: 6
    Last Post: 04-12-2017, 08:56 PM
  3. Replies: 0
    Last Post: 04-12-2013, 02:18 PM
  4. Menz SF4500 /Optimum Finish Polish/WG Finish GLaze
    By primo spaghetti in forum Ask your detailing questions!
    Last Post: 11-03-2012, 03:25 PM
  5. Sonax Cut & Finish and Sonax Perfect Finish at Autogeek.net
    By Mike Phillips in forum New Car Care Products
    Last Post: 06-22-2012, 08:03 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
