Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    May 2019
    48
    How to remove these stains from the rims?
    I purchased a new Infiniti 3 months ago and dealer had the tires dressed with some cheap material that must have spilled on the rim and stained them, so far my detailer used even some wheel acid with no luck and he did not want to push it more and cause any damage to its clear coat. Only one side, 2 out of 4 wheels are like this, the other two are clean. Can anyone help and let me know what you suggest would be the best way to get rid of these stains?
    Attachment 67516Attachment 67517Attachment 67518Attachment 67519Attachment 67520
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Re: How to remove these stains from the rims?
    You could try a compound or a polish to see if it helps.
    May 2019
    48
    Like hand polishing?
    May 2017
    262
    How is this NOT the dealer's fault (and problem to fix)? They were the ones who used whatever god awful product which caused it.
    Yes, Guz meant hand polishing. The Poorboys 'sampler' has 4 small bottles of all their polishes.
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Having the dealer try to "Fix" it may very well lead to worse problems.
    I would absolutely try and fix this myself.
  6. Likes kamisn liked this post
  7. #6
    May 2019
    48
    Quote Originally Posted by howardm4 View Post
    Yes it’s their fault, but I haven’t brought it up to them yet as I haven’t took it for first service yet but also as PaulMys said they may make it worst or just offer to repaint them which is the last thing I want them to do. I will give the polish a try, I am not sure if it works as it looks like it blended to the paint rather than being on it.
  8. #7
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by kamisn View Post
    If the polish doesn't work, go see the dealer ASAP
    Point the problem out, and tell them if they cannot correct it, you want a set of brand new wheels.
    Insist on it.
  9. Likes kamisn liked this post
  10. #8
    Jun 2013
    LA, CA
    8,719
    Yes this is exactly what I meant. Go to your local auto parts store and get yourself some Meguiar’s ultimate compound. You can work it with a foam applicator or a microfiber towel.
  11. Likes kamisn liked this post
  12. #9
    May 2019
    48
    I think the stain is actually the paint primer, I tried MUC on a test spot and ended up with some black flake spots which I think is the paint that is gone (the flakes are smooth with no raised/dip edge), now I think the original stains are not really stains, it's the primer that is visible. I am so pissed at the stupid dealer's detailing guys , who does such a stupid thing?! the wheels are $700 a piece.
    Attachment 67557
  13. #10
    Jun 2013
    LA, CA
    8,719
    So the compound removed a little of the stain? You may need to step up to some mineral spirits. When I dropped my car off to get painted, the wheels had overspray all over them that mineral spirits was the only thing that was able to remove. The clear coat was intact after all that.
  1. How to remove stains from these two areas
    By choijw2 in forum Auto Detailing 101
    Last Post: 12-17-2016, 05:10 PM
  2. Stains on rims
    By SightHound01 in forum Auto Detailing 101
    Last Post: 06-01-2016, 11:38 PM
  3. How to remove seat stains?
    By AutoApollo in forum Auto Detailing 101
    Last Post: 03-21-2016, 09:20 PM
  4. Removing yellow stains from chrome rims
    By JMCamaroSS in forum Auto Detailing 101
    Last Post: 09-05-2015, 10:20 PM
  5. How to remove Iron (Well Water) Stains from Paint, Trim, & Rims
    By BearsFan315 in forum Auto Detailing 101
    Last Post: 07-28-2014, 06:54 AM
