Results 1 to 7 of 7
    Jun 2019
    Removing mud stains, single stage white paint
    New to the forum. So...I’m trying to do paint correction on a White 2007 Toyota Tundra. The truck hasn’t had any wax in several years. To make matters worse it has been covered in mud for about a year without a wash, baking in the south Louisiana/Southeast Texas sun 24/7. It is very oxidized and stained. I think my plan is, after initially washing with Dawn, I’m using Griot’s Garage Sythetic Clay pad with Speed Shine. Then I’ll use Pinnacle Advanced Compound to remove the oxidation and stains before applying a protectant. My question is; how much effort should I put into removing the stains with the clay? Should I just get the above the surface stuff with the clay and leave the stains for the compound? Or should I put a lot of effort into getting as much of the imbedded dirt out as possible?
    Re: Removing mud stains, single stage white paint
    Quote Originally Posted by SlidinSidways View Post
    My question is;
    Clay, or in this case a Griot's Garage clay mitt, will only remove TOPICAL defects. I will do little if anything to deep clean single stage paint.
    The compound will shine in this area - pun intended.
    Don't want to say you from your plan and if you plan to use a ceramic coating then you don't want to use an AIO or cleaner/wax. BUT if all you want to do is remove the staining, restore the shine and make the process quick and simple - get some BLACKFIRE One Step.
    Use it HEAVE or WET, this means use an ample amount and plenty of foam cutting pads and the chemical cleaners and solvents PLUS the abrasive technology will/should restore a vibrant white appearance - no problems.
  3. Likes SlidinSidways liked this post
  4. #3
    Here's a TOTALLY different issue (micro-marring), but in this member's original post asking for help I stated the BLACKFIRE One Step would fix the problem and true to my word - it did.
    Updated - Blackfire One Step makes a newb not feel like a newb...amazing product
    Super nice product and easy wipe-off. I call this product,
    Bubba-Proof
    The only way you could make a mistake with it is if you held it a few feet over the hood and dropped it.
  5. Likes axel06 liked this post
  6. #4
    Jan 2015
    131
    Toyota has been using SS white paint on many trucks. I have a 2010 Tundra with SS factory white paint sitting on the property right now. Are you saying they didn't in 2007 for some reason?
    Sent from my SM-G930V using Autogeekonline mobile app
  7. #5
    Jun 2019
    Thanks, Mike, for the quick reply.
    I am considering ceramic. Never done it before. Figured the Tundra would be a good vehicle to learn on, but I have a ton of issues to try to address before I make a final decision on that. It’ll be more about the learning experience than the final outcome. This truck has been used and abused probably beyond my ability to totally repair, but I’m gonna give it a go. At least make it “less embarrassing” for my son to drive.
  8. #6
    Jun 2019
    Quote Originally Posted by Coleroad View Post
    Was it repainted? Because a 2007 tundra didn't come with single stage paint from the factory.
    No. It’s never been repainted, Super White (040)
  9. #7
    Jun 2019
    Hahaha. Dang!!!
  1. White Single Stage Paint
    By Saibot in forum Ask your detailing questions!
    Last Post: 01-07-2020, 06:25 PM
  2. What wax do you like for single stage white paint (Ford Oxford White 9L)?
    By gbrittenum in forum Ask your detailing questions!
    Last Post: 04-16-2019, 05:44 PM
  3. Stains around body lettering on single stage white paint
    By fett701 in forum Ask your detailing questions!
    Last Post: 05-13-2015, 07:18 PM
  4. White single stage paint
    By DaveT435 in forum Ask your detailing questions!
    Last Post: 03-24-2015, 08:38 PM
  5. Brake Fluid stains in single stage paint?
    Last Post: 12-14-2012, 11:05 AM
