Results 1 to 10 of 10
    Sep 2010
    204
    BLACKFIRE Pro Ceramic Coating: Any long term evals out there?
    I was watching WaxMode's short video: YouTube and read Mike Phillips review and how to: Review & How-to: BLACKFIRE Pro Ceramic Coating by Mike Phillips for Blackfire Pro Ceramic Coating. I have been waiting for New England weather to work on my black 2017 Honda Accord Sport SE. I am a consumer, not detailer. I have a syringe of Optimum Gloss Coat sitting on my shelf.
    But I recently ran into the BFPCC posts and videos, and maybe I should try this instead of Optimum Gloss Coat.
    However, I have not read/seen any long term evals. It appears that this coating was ?? recently released???
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Re: BLACKFIRE Pro Ceramic Coating: Any long term evals out there?
    Quote Originally Posted by charlestek View Post
    Don't let all the advertising BS sway you. Optimum, Blackfire, Car Pro, Ceramic Pro, Gyeon are all well known and respected brands. Nothing wrong with OGC, use it since you have it.
  3. Likes PaulMys, spazzz, The Guz liked this post
  4. #3
    Sep 2010
    204
    Yeah, I know I should be careful discussing politics or ceramic coatings. Once upon a time, I remember something like someone doing a massive independent comparison test of ?waxes with a rectangular grid
    of green tape on some kind of body panel. Maybe someone can grab a junked car and apply different brands of ceramic coating in a grid on the hood and roof and drive through say a desert sand storm or a horrific winter, and then post the results.
    Or maybe I should ask which ceramic coating is the hardest to polish off, after say hmm, a "detailing accident"
  5. #4
    Super Member Mgavin1985's Avatar
    Nov 2017
    497
    Check YouTube a dude has done that
  6. #5
    Sep 2010
    204
    Quote Originally Posted by Mgavin1985 View Post
    Mgavin,
    Thanks. I will do a youtube search and see what is out there.
    Also, apparently no one has "detailing accidents". Or maybe there is a thread on this site where people have posted these???
  7. #6
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Junked Cars...driven?
    If you’re willing to pull the permit(s)—not sure
    of the local ordinances (don’t want to overstep
    any boundaries of lawfulness)—I will take the
    necessary steps to see if my busy schedule will
    permit me the time to conduct your tests.
    Please keep me apprised.
  8. #7
    Sep 2010
    204
    Bob,
    I worded that poorly. I was first thinking that a junked car's paint could be used as a testbed. Then I realized that it would be better if it could drive. I should have said "junker that runs", or maybe "my relative's car when they aren't looking".
  9. #8
    Sep 2010
    204
    Mgavin,
    I just watched a 3 month after video on youtube of various coatings, but waxes also. But the guy insists on spraying the test hood vertically sitting on the ground with a pressure washer to test beading, instead of using normal pressure with say a soaker setting. Some of the areas on the lip of the hood are bent backwards by the normal contour of the hood and would affect things slightly. He also does not hand wash the area with a mitt after dispensing soap by pressure washer. With no mechanical agitation of the car wash by a hand mitt or other, I'm not sure if this would change the results.
    In any case, CK Quartz UK looks a hair subjectively better than Gloss Coat, but nothing dramatic.
    No Blackfire ceramic tested here.
  10. #9
    Super Member JustJesus's Avatar
    Oct 2014
    Orange & LA Counties
    1,294
    Sure they do. I think Mike P has mentioned this in some posts. Having high spots, and removing them.
    Also, I saw a video with Optimum (maybe rag co video?) purposely leaving a high spot, then removing it at the "end" of that application.
  11. #10
    Super Member prin's Avatar
    Oct 2008
    Huntsville, AL
    264
    Quote Originally Posted by JustJesus View Post
    I have had such accidents. I think it was due to the heat and humidity. I was detailing a customers BMW 750li black in color. I was doing this at night since they wanted it done at their house. Well, under my lights, everythign looked perfect! I when there the next day and whoa!!! It was streaked to hell and back. I waited untill I opened my shop and I redone the car for them. I had to explain that the heat and humidity would not let the coating cure properly. They understood and I was able to buff off the coating and recoat. It was the blackfire. This is the only coating that I use for 1-3 year coating. I like the way that it flashes as well.
  1. How safe long term are ceramic coatings on headlights?
    Last Post: 12-05-2019, 01:32 PM
  2. Long Term Ceramic Coating Storage?
    By ejaf in forum Auto Detailing 101
    Last Post: 09-29-2019, 08:13 AM
  3. Long Term Wear of Ceramic Coatings?
    By haze10 in forum Auto Detailing 101
    Last Post: 09-15-2019, 06:57 PM
  4. Long term Wolfgang Uber Ceramic Coating update!!!!
    By Justin at Final Inspection in forum Auto Detailing 101
    Last Post: 01-07-2017, 02:09 AM
  5. Wolfgang Uber Ceramic Coating Long Term Results
    By Hokie335i in forum Product Reviews
    Last Post: 04-02-2016, 02:12 PM
