Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Regular Member Chevota Guy's Avatar
    Jun 2013
    Palm Springs, CA
    115
    How restore deep satin black between cab windows ?
    I recently polished a 2007 Tundra with Meguiars D166. Now that the truck is so shiny, the faded black panels (decals ?) between the cab windows are really an eyesore. I tried some 303 Aerospace Protectant, but they are splotchy and greasy looking. Anyone know of a way to clean these and restore the deep black satin look ? I've noticed a similar black treatment on many different makes and models and it is thick enough where I don't think it is paint. I'm concerned about rubbing through them as they may be decals.
    How restore deep satin black between cab windows ?-img_4008-jpg
    How restore deep satin black between cab windows ?-img_4009-jpg
    Rick......(Spelled with a "D" )
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Re: How restore deep satin black between cab windows ?
    For something like that I’d first try Hyper Polish or McKee’s paint prep polish. Both work incredibly well on vinyl and smooth black trim. If either of those works, I’d top with PNS or BSD.
    I was going to say if it was yours or a friends, just put some new vinyl on. I have a 2010 Tundra and when mine was getting too thin to be polished out, I just removed it and installed some 3M Dinoc carbon vinyl. Very subtle, yet noticeable.
    Jun 2013
    Palm Springs, CA
    115
    Quote Originally Posted by fly07sti View Post
    Thanks much for the suggestions. On mine, the black extends beneath the rubber trim adjacent to the panels so I think it would be difficult for me to do a clean edged job if I were to try rewrapping, but it might be the way to go.
    As far as PNS goes, I just tried it a few days ago over the D166. I'm anxious to see how it holds up in the desert heat.
    Sep 2018
    282
    Hard to tell from the images but based on the fading pattern and gloss levels, it looks like it is vinyl wrapped.
    If you were to fix it, re-wrapping would be the way to go (even if it is painted). To get the best result you’d need to remove the door sills clean and prep the area before wrapping. That way there’ll be no edge visible and in fact, you won’t have to get the edge perfect as the sills will hide it.
    Jun 2019
    110
    Armour all
    Despite thousands of "restore, trim rubber etc." on the market, every single one i have tried leaves streaks
    Nov 2015
    Los Angeles, California
    13,797
    There’s 2 ways to fix that. Either the D166 itself can do it, or it’s that non porus plastic..
    If it’s made of that non porus plastic, the best way to restore it back to new is to use a paint cleanser like McKee’s Coating Prep Polish.
    Here’s what the non porus plastic on my fathers 2004 Toyota Tacoma looked like.
    Coating Prep Polish. Applied with a terry microfiber applicator [you can also use a wet Magic Eraser with the polish]
    After.
    Restored it to brand new condition.
    That’s not some cover up product that will fade away in a couple of weeks... That’s how it really looked on its own because it was truly restored.How restore deep satin black between cab windows ?
  7. Likes ssnimrod liked this post
  8. #7
    Jun 2013
    Palm Springs, CA
    115
    Folks, I really appreciate all the helpful suggestions !
    After.
    The restoration on that '04 Tacoma is absolutely great. I have some D166, but think I need to try the McKees coating prep. I'm looking forward to getting this fixed. Thanks again, I really value all of the free sharing experiences folks here so willingly provide
  9. Thanks Eldorado2k thanked for this post
    Likes Jim w liked this post
  10. #8
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    What is the original finish? Is it matte? If it is then don’t polish it unless you want that gloss look. Once polished you will lose that matte look for good.
  11. #9
    Jun 2013
    Palm Springs, CA
    115
    It isn't matte, rather smooth and satin, but no substantial gloss, so I'm thinking about doing a very small test spot. Unfortunately there isn't an inconspicuous place since they're at eye level.
  12. #10
    Nov 2015
    13,797
    I’d be more cautious with applying the wrong kind of trim restoring product than I would be with polishing it. If it’s what it looks like, no trim restoring product will work any good and if anything could have an adverse effect.
    Quote Originally Posted by Chevota Guy View Post
    It isn't matte, rather smooth and satin, but no substantial gloss, so I'm thinking about doing a very small test spot. Unfortunately there isn't an inconspicuous place since their at eye level.
    You can do a test spot.. Just lay down some tape to where you leave a nice thin straight strip for you to test on. Best way is to go thick on the tape on both sides so it leaves you all the room to do your thing while staying within the tape lines. Then once you remove the tape even if it turned out less than stellar, at least it’s only a thin perfectly straight strip going across the trim.
  1. Restore non-glass windows in 1979 MG MGB convertible hood (top)
    By CMHMHH in forum Ask your detailing questions!
    Last Post: 10-24-2020, 07:07 AM
  2. Replies: 2
    Last Post: 07-28-2018, 09:35 PM
  3. Cars with satin black wheels/powder coated (black)..
    By Maestro Sam in forum Auto Detailing 101
    Last Post: 11-14-2016, 07:06 PM
  4. Sonax on Satin Black Wheels
    By Regency in forum Auto Detailing 101
    Last Post: 11-30-2014, 01:43 AM
  5. how to correct this satin black paint
    Last Post: 04-29-2012, 09:25 PM
