Re: What is a good product to fill swirls?
Prima Amigo does a great job "filling" imperfections, especially on dark paint.
But you will not have great or permanent results if you don't address the swirls.
Maybe think about stepping up to an AIO to get better, longer lasting results.
2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
Klasse Sealant Glaze works well for minor swirls and has a layering effect. Works even better at at 1:3 ratio with water. I documented it with pictures on Autopia about 10 years ago. Takes about 3 layers before you start noticing results.
Thanks all for the reply, much appreciated
Add Collinite 476 and, although I’m not big fan of it overall, Meg’s NXT / M21 fills very well, even better in unison with D156... actually if I was trying to fill swirls as a main goal I would dig this combo out from my back shelf.
Anyone remember danese wetglaze? Poorboys black hole was good but essence plus is better and durable
Originally Posted by
Mgavin1985
I remember them well and they all didn't work..not on black paint anyway. Even Essence Plus did not do a very good job. I tried by hand by machine. Heavy, light, remove right away, let sit for a few hours. Tried layering, it helps a little, but I can still see the fine lines.
Burn133
Im looking for a good product that I can wipe on, and wipe off and will fill in small swirls in the clear coat, and make it look like the paint has been corrected. I know about paint correcting, compounding and polishing but thats not the route I want to go. I also know a filler glaze will be temporary and will have to be done several times a year.
Thanks for your help
Check out CarPro Reload. Liquid spray sealant. Wipe on, wipe off application. Fills like crazy and super quick to apply.
Nicholas@Autowerx
I have to politely disagree with this. I’m sorry.....
However Carpro Hydro2 fills considerably and it’s easy application....!!!
DetailKitty
Agreed. Forgot about Amigo on my original reply.
MattPersman
I used to love thay stuff.
It used to be called Zymol Auto Polish, and came in a fancy plastic packaging.
It still has that same delicious coconut/banana scent too...
I don't remember it really filling, but do remember it being very aggressive, and effective.
Even their HD Cleanse was pretty effective at actually removing some light scratches.
