Results 1 to 8 of 8
    Mar 2019
    Removing ghosted images from lettered van and trailer?
    Wondering what the best way to go at it would be, once the vinyl lettering is removed there is always that burned in image of what was there. Is there even a way to really get it out? I’m going to be selling my work vehicle and I want to get all my company info off of there. Not dealing with a huge area, small logo and a couple lines of text. Might it come out with compound? Have to wet sand? White Chevy cargo van.
    Also a different type of paint but I have to do the same thing on my cargo trailer. Much smaller area that I just have to alter with some updated website information but I don’t know how aggressive you can get on that cheap metal they build the trailers with and if it’s even automotive paint.
    Aug 2013
    St Louis metro (Illinois)
    5,809
    Re: Removing ghosted images from lettered van and trailer?
    I've not had any success on removing the ghosting, but fortunatly it was on a much smaller scale. When we bought my daughter's car it had vinyl pin stripes down the doors which had faded and cracked. After removing the stripes and even polishing out to the doors the ghosting is still there.
    Super Member Belo's Avatar
    Jul 2014
    Rochester, NY
    492
    If I'm not mistaken, it's a paint discoloration issue from the sun for which there is no cure besides a new paint job. It's similar to why touchup paint is such a tricky task.
    2009 Pontiac G8GT
    2015 Ford Explorer Limited
    2019 Chevy Silverado RST Z71
    Quote Originally Posted by SwirlmarkIII View Post
    I've never seen ghosting removed 100%.
    You can get it to the point it's a lot less visible but not gone 100%
    Same on boats. Look at all the pictures of the boats we've detailed in our boat detailing classes. Most of them had lettering at some time. We machine sand them with #1000 and #2000 (followed by #3000 and #4000), and even with MAJOR sanding - if you look close you can still see where the lettering was.
    Just compound hard (within reason), then polish and wax. Stick a fork in it and call it done.
  5. Likes Farmallluvr, mdbenge liked this post
  6. #5
    Mar 2019
    Sounds good thanks everyone
  7. #6
    Jun 2013
    Montreal, Quebec
    3,996
    A paint correction will remove one of the factors that make the drastic look: Damage. The paint where the lettering was is very likelly pristine, and the paint around it is swirled up and oxydized. So it's like having 2 different paint texture and color next to each other. If you compound and polish the paint, they should be very close to a match afterwards.
  8. #7
    Jul 2013
    Apex, NC
    1,283
    If it is a white cargo van, then the white paint maybe single stage paint. You can't do anything about the unfaded base color that was under the lettering when it is clear coated, because it is the base coat underneath the clear that has faded on the rest of the car. If it is single stage paint then your results will come out much better since the fading is on top.
  9. #8
    Jul 2014
    Rochester, NY
    492
    part of me wonders if you apply zero protection to the paint, will the lettered area fade to a similar shade? lol
    2009 Pontiac G8GT
  1. Removing oxidation on travel trailer with Filon siding
    By fletcher33 in forum Ask your detailing questions!
    Last Post: 07-15-2016, 08:53 AM
  2. D-Day images - then and now
    By Docpeanut in forum Off-Topic
    Last Post: 04-05-2015, 06:14 PM
  3. Converting utility trailer to enclosed trailer
    By Santana White in forum Off-Topic
    Last Post: 06-14-2013, 05:46 AM
  4. Square One Detailed - 2006 Ghosted Dodge Charger
    By RhetoricMixes in forum Show N' Shine
    Last Post: 04-16-2013, 05:04 PM
  5. Free images to use on your website
    By FlgStudios in forum How to make money detailing cars
    Last Post: 07-14-2012, 09:35 AM
