Page 28 of 28 FirstFirst ... 1819202122232425262728
Results 271 to 278 of 278
  1. #271
    Apr 2019
    33
    Re: Optimum Tire Protection Coating (TPC)
    I just got new wheels/tires and plan on using this coating. In the videos from Apex detailing and Pan the organizer (featuring Yvan Lacroix) they both applied in sections and worked it in right away and mentioned if there is a blue/purple tint than there is too much product. I noticed in some of the pictures here some of you have an entirely blue tire? Yvan Lacroix also mentioned he recommends only 1 coat even though 2 is possible. I read a few of you did 2-3+? I‘m wondering if that’s the reasoning behind the browning. My current dressing is CP PERL but this stuff is pretty cheap so I’m tempted at the thought of a longer lasting dressing.
  2. #272
    Super Member Rrthomas78's Avatar
    Dec 2017
    346
    Quote Originally Posted by Rand0m View Post
    Imo yes over application will cause the browning also the prep work has to be followed to the t. The first time I used it I just kept putting on coats because it looked splotchy to me...and it turned to sh*t. Also it's not that easy to remove. Less is more with otc
    Sent from my SM-A205U using Autogeekonline mobile app
  3. #273
    May 2020
    92
    I applied this over the weekend and it went pretty poorly. I used a circular microfiber application pad and the coating dried extremely streaky and uneven. The tires, a new set of Vredestein Quatrac Pros, were thoroughly cleaned with a few applications of Power Clean and dried with heated filtered air. It almost felt like the coating dried instantly on the tires even though it was only about 60-65 degrees out. I'm also wondering if I didn't apply enough product to the applicator and had to keep adding more to it for each quarter I applied it to.
    At this point the tires look so bad I'm going to have to remove the coating and either try again or go back to my usual CG VRT (or make the switch to Carpro Pearl or Gyeon Tire). I do have Gyeon Tar on hand and more Power Clean to try and get the coating off. Are those two chemicals, a good tire brush, and thorough scrubbing going to be enough to get it off? If do reapply the coating is there a type of applicator or sponge that would work better?
  4. #274
    Feb 2012
    Palatine Illinois, USA
    24,668
    Maybe that protective coating from the factory is still on there and/or needs to out gas, I mean they are brand newOptimum Tire Protection Coating (TPC)
    2022 Elantra N Cyber Gray
  5. #275
    May 2020
    92
    It's possible but I've had the tires for over a month and who knows how long they were at Tire Rack before being shipped to me. I'm not seeing any browning so it's likely something I did wrong when applying to coating to the tires. Be it a poor quality microfiber applicator and having the same application issue Rrthomas78 had. Seeing that the coverage wasn't ideal, going back over it again, and it turning into a uneven streaky mess.
    Once I get the coating off I may try repplying to one tire and see how that goes. Maybe try a better quality microfiber square applicator or a grooved foam style such as the Speed Master Tire Dressing Applicator.
  6. #276
    Sep 2016
    128
    I used Optimum Tire Protection on a new set of tires, and it was terrible, had to painfully remove it. Same tires, 2,000 miles later, it worked great. I clean them until pure white foam shows on the tire. Like 5 or 6 rounds of cleaning with Power Clean and a power scrub brush. I've also used Tuf Shine, which required even more cleaning in my experience, and that product works great too.
  7. #277
    May 2020
    92
    I spoke with Optimum's customer service over the phone and they confirmed my suspicions. My tires were too new and my application was poor. A few of them have also started browning since I applied the coating. I've ordered some Optimum T.A.R. and it should be here by the end of next week. Getting the coating off will likely be a real pain but lesson learned. I'm not sure I'll give it a try again in a few months though.
  8. #278
    Feb 2012
    24,668
    Use mineral spirits on the tires tooOptimum Tire Protection Coating (TPC)
  1. Poor performance by optimum tire protection?
    By TheMidnightNarwhal in forum Auto Detailing 101
    Last Post: 03-27-2020, 05:58 PM
  2. Optimum Tire Coating and Tire LEttering
    By ozzywannabe in forum Auto Detailing 101
    Last Post: 02-11-2020, 12:03 AM
  3. Replies: 16
    Last Post: 04-09-2019, 12:43 PM
  4. OPT Optimum Tire Protection & Coating
    By Harsh in forum New Car Care Products
    Last Post: 01-06-2019, 09:46 PM
  5. Replies: 6
    Last Post: 08-21-2017, 09:27 AM
