Page 17 of 28 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 161 to 170 of 278
  1. #161
    Feb 2012
    Palatine Illinois, USA
    24,801
    Re: Optimum Tire Protection Coating (TPC)
    Ok....I applied a 2nd coat and while I didn't notice the brown, dry look I did notice small "sections" of tan but I just applied over the top of it. All I know is this, I've never had an experience like THIS with any other product. Yes I never did a heavy duty cleaning prior to this but I also never did it with any other product either, so while the jury is currently out the tea leaves are out thereOptimum Tire Protection Coating (TPC)
    2022 Elantra N Cyber Gray
  2. #162
    Sep 2018
    282
    Did this happen to be on the front tires?
    There are small sections of discolouration on the inner radius of the tire wall on the fronts in the last set of pictures you posted.
  3. #163
    Super Member bfielder32087's Avatar
    Feb 2018
    517
    Reading this thread is one of the many reasons I have no interest in tire coatings. I've only ever used the Tuff Shine costing. Like most I didn't have the tires clean enough with the first application and it looked like hell.
    Fixed that mistake when applying it the 2nd time and still just wasn't impressed. Didn't love the look. For me PERL is the best looking tire dressing out and there isn't any of the finicky issues you get with TS and some other dressings. Takes me maybe 5 minutes to reapply after each wash and I RARELY see any kind of browning. Just give it a light cleaning with a RW product or a heavily diluted APC and brush it on, them knock down any high spots with an applicator. Every 3 months or so I'll do a deep cleaning to strip it all off and any kind of dirt and reapply.
  4. Likes Coatingsarecrack liked this post
  5. #164
    Feb 2012
    24,801
    Quote Originally Posted by WristyManchego View Post
    Yes
  6. #165
    Dec 2018
    7,235
    Yeah Mike Phillips only recommends on new tires to use tire coating. Cleaning old ones is a PIA and if not totally clean you gotta redo. I do feel the TAC systems tire coat is more forgiving. I apply monthly 1-2 coats and performs well.
    I suspect it being more forgiving is why durability is less. I got 2 months of protection and probably coulda got a 3rd but appearance wasn’t up to snuff for me.
    Acura, PERL is my favorite and I felt 2 coats had that Perl sheen and was more durable. For the price you should give it a try.
  7. #166
    Feb 2012
    24,801
    TAC system tire coating isn't a true coating, it doesn't have that bluish/purple color in the mix when applying.
  8. #167
    Jun 2013
    Montreal, Quebec
    3,996
    Quote Originally Posted by Finick View Post
    The issue I encounter with the stuff is that I can’t spread it around. Before I make it 1/3 of the way around the tire, the stuff has become dry and impossible to spread around. It’s really, really weird.
    My gut tells me to use more product, but I keep operating under the impression that it shouldn’t take much product at all to cover the tire. Next time I pick a tire to apply to, I may just apply more than I think I need. It certainly can’t come out worse than it has in previous attempts.
    Hum... I did not use much product at all so far. I use a foam applicator for tire dressing, make a line of product along the long axis. Probably used about half an ounce to do 4 tires.
    I did not get the drying effect while applying. So my guess is yes, you did not use enough.
  9. #168
    Jun 2013
    Montreal, Quebec
    3,996
    Quote Originally Posted by Belo View Post
    just went through this with PBL wheel coating. directions really hit on using their surface cleansing polish. I have tons of polishes, cleaners and strippers... do I really need this I ask myself? The coating is $60... another $30 for another bottle on a crowded shelf?
    And then if it doesn't work as you had hoped there is this element of doubt. Is the product just not as advertised or is it my fault for not following the directions 100%...
    My rule of thumb is: Only switch product when the previous one is empty. Otherwise you will end up for 50 bottles of stuff all doing the same thing and some of them going bad before you can used them.
  10. Likes Klasse Act liked this post
  11. #169
    Super Member Finick's Avatar
    Jul 2017
    885
    Quote Originally Posted by Calendyr View Post
    My last attempt at applying it was done with one of the speedmaster tire dressing applicator sponges: Speed Master Tire Dressing Applicator
    It was a much better attempt than using a microfiber applicator/towel, but I still put about 3 lines of product on to the foam and it still didn't give me hardly any time at all to spread it around. it's very odd.
  12. #170
    Dec 2018
    7,235
    I don’t think color makes it a coating or not. It is an acrylic based resin which McKee’s tire coat also claims to be. Lasted a couple of months for me which no dressing has.
    It’s definitely a coating just not as durable as others.
  1. Poor performance by optimum tire protection?
    By TheMidnightNarwhal in forum Auto Detailing 101
    Last Post: 03-27-2020, 05:58 PM
  2. Optimum Tire Coating and Tire LEttering
    By ozzywannabe in forum Auto Detailing 101
    Last Post: 02-11-2020, 12:03 AM
  3. Replies: 16
    Last Post: 04-09-2019, 12:43 PM
  4. OPT Optimum Tire Protection & Coating
    By Harsh in forum New Car Care Products
    Last Post: 01-06-2019, 09:46 PM
  5. Replies: 6
    Last Post: 08-21-2017, 09:27 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
