Page 15 of 28 FirstFirst ... 5678910111213141516171819202122232425 ... LastLast
Results 141 to 150 of 278
  1. #141
    Feb 2012
    Palatine Illinois, USA
    24,560
    Re: Optimum Tire Protection Coating (TPC)
    Quote Originally Posted by WristyManchego View Post
    Is this a reapplication or post spirits cleanup?
    This was after the 2nd reapplication and sitting for 11 hrs but the p/s was not exposed to direct sunlight, only the d/s.
    2022 Elantra N Cyber Gray
  2. #142
    Super Member BudgetPlan1's Avatar
    Dec 2015
    Central OH
    2,000
    Question for all in general, has anyone used a tire coating where dressing can reapplied after? The Tac system isn’t failing protection wise after 4-6 weeks but doesn’t have that semi gloss look I like.... more like a clean tire.
    I tried applying Perl to it but it would bead up. After smearing it in with aMF applicator it would even out but would get runs in it if it got wet. Basically the coating self cleaning the dressing off. I used PERL 1 to 1 for dressing.
    With TuffShine I generally clean tires 2 or 3 times a year and reapply and let it ride. Doesnt give that really glossy shine, rather a clean, slight sheen.
    It did really gloss up on some Michelin PS Sport A/S ZP tires though, have used on other Michelins without it getting glossy so as mentioned, different tires may produce different results.
  3. Thanks Coatingsarecrack thanked for this post
  4. #143
    Feb 2012
    24,560
    Just inspected all 4 tires with my cellphone LED light....all 4 ARE brownOptimum Tire Protection Coating (TPC)
  5. #144
    Sep 2018
    282
    There is a reaction happening with the solvents in the compound either pre-existing or detailer-added.
    I agree with what others have mentioned about a tyre cleaner followed by a hydrocarbon/white spirit rub down. Then let sit for a week and repeat before trying again.
    Considering you’ve used a lot of tyre shine in the past, great lengths are needed to get the compound properly clean.
  6. Thanks Klasse Act thanked for this post
    Likes Klasse Act liked this post
  7. #145
    Feb 2012
    24,560
    Ok, I got to work this morning and sprayed all 4 tires with Super Clean aerosol. After I sprayed all 4 I then went back and wiped them down. During the foaming process I noticed brown being lifted from the tire. One little side note, even though the tires are the same brand my front tires have been replaced, looked at the date on the tire, also they don't have rim protection like the originals, not sure why the new ones weren't made the same. Anyway, here's how they look after the cleaning:
    You can clearly see the rears look better than the fronts do, hmmmOptimum Tire Protection Coating (TPC)
  8. #146
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    Fronts get more "exercise" than the rears. I always notice my front tire dressings/coatings seem to dull a little faster.
  9. #147
    Feb 2012
    24,560
    Quote Originally Posted by Paul A. View Post
    True enough but look at the difference after the cleaning.
  10. #148
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Quote Originally Posted by BudgetPlan1 View Post
    Isn't TS like most tire dressing/coating, the more coats, the glossier it gets?
  11. #149
    Jan 2007
    14,095
    What are rim protection?
  12. #150
    Feb 2012
    24,560
    Some tires have a raised portion of rubber that goes around the rim for a little added protection for the edge.
    Ok, so tonight I'm going to wash the car but another round of cleaning is going to happen with Super Clean aerosol but scrubbed and rinsed down. I will then Read apply the product to the tire and see what happens.
  1. Poor performance by optimum tire protection?
    By TheMidnightNarwhal in forum Auto Detailing 101
    Last Post: 03-27-2020, 05:58 PM
  2. Optimum Tire Coating and Tire LEttering
    By ozzywannabe in forum Auto Detailing 101
    Last Post: 02-11-2020, 12:03 AM
  3. Replies: 16
    Last Post: 04-09-2019, 12:43 PM
  4. OPT Optimum Tire Protection & Coating
    By Harsh in forum New Car Care Products
    Last Post: 01-06-2019, 09:46 PM
  5. Replies: 6
    Last Post: 08-21-2017, 09:27 AM
