Re: Q: ceramic over xpel...overkill?
SO I see a few of you guys saying that PPF will not stick to a Ceramic coating and should not be put on first.
I bought a new car in 2016 and I brought it home, applied Cquartz UK and then a few days later I got the full front end covered in PPF. I have had no issues with it not sticking, I also asked the installer before if it would be an issue and he said no it would not (he was correct) I have also put Ceramic coating on the PPF (as others have mentioned in this thread) without issues.
Now I dont know if its because I used a consumer grade ceramic coating and maybe its not as good as the Pro stuff some of you may install but I never had issues with the PPF going on top of my ceramic coating
Originally Posted by
bryanviper
It can cause bonding issues and most film manufactures won't warranty it if it lifts when the paint has been coated. I've seen plenty of installers say they've had issues with it too, though I think it's going to be more of an issue with coatings that leave the paint feeling slick to the touch.
This weeks VIP special
Reviving this thread as I have a client who wants to get his Corvette ppf and coated.
Rasky, to your point on the film hiding swirls and doing minimal to no polish, I guess you're right that that's up to the client. I suppose if you did a minor correction, same as applying any lsp, wipe off any oils?
The ppf will be installed elsewhere after I correct the paint. Rinseless or waterless wash is a good recommendation for the ppf installer before they install the film down?
Sent from my ASUS_X017DA using Tapatalk
Jon TDS
If the PPF installer is any good, they will know how to prep the paint, including getting the polishing oils off.
Rsurfer
Honestly. All the best PPF installers in my area just come, wash the vehicle, clay bar, IPA and start wrapping. Some quick touch up paint if needed. Never had any issues. These are people who have done this for 15+ years and do all the exotic car dealerships in the area. True PPF artists.
Never once have I seen them use a buffer.
